Topic: my VDJ is opening and shutting down immediately....any idea?
Translated Report (Full Report Below)
Process: VirtualDJ [1271]
Path: /Applications/VirtualDJ.app/Contents/MacOS/VirtualDJ
Identifier: com.atomixproductions.virtualdj
Version: 8.5.8346 (18.0.8350)
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2024-11-01 00:05:41.2218 +0100
OS Version: macOS 15.0.1 (24A348)
Report Version: 12
Anonymous UUID: 017175E1-DF91-BAE8-B71E-66A2AEB85F21
Sleep/Wake UUID: 3A766DB3-0066-4A5F-9049-8F357A81AC0F
Time Awake Since Boot: 780 seconds
System Integrity Protection: enabled
Notes:
PC register does not match crashing frame (0x0 vs 0x7FF8045F59F2)
Crashed Thread: 17 worker
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [1271]
VM Region Info: 0 is not in any region. Bytes before following region: 4307857408
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 100c4b000-106094000 [ 84.3M] r-x/r-x SM=COW /Applications/VirtualDJ.app/Contents/MacOS/VirtualDJ
Error Formulating Crash Report:
Thread 0:: Dispatch queue: com.apple.main-thread
0 ??? 0x7ff894756a84 ???
1 libsystem_kernel.dylib 0x7ff804581e0e mach_msg2_trap + 10
2 libsystem_kernel.dylib 0x7ff804590622 mach_msg2_internal + 84
3 libsystem_kernel.dylib 0x7ff804588f16 mach_msg_overwrite + 649
4 libsystem_kernel.dylib 0x7ff8045820ff mach_msg + 19
5 CoreFoundation 0x7ff8046a93a3 __CFRunLoopServiceMachPort + 143
6 CoreFoundation 0x7ff8046a7e0b __CFRunLoopRun + 1393
7 CoreFoundation 0x7ff8046a72aa CFRunLoopRunSpecific + 536
8 HIToolbox 0x7ff81017cfe3 RunCurrentEventLoopInMode + 292
9 HIToolbox 0x7ff8101829c4 ReceiveNextEventCommon + 646
10 HIToolbox 0x7ff810182b62 _BlockUntilNextEventMatchingListInModeWithFilter + 66
11 AppKit 0x7ff807f43d8b _DPSNextEvent + 902
12 AppKit 0x7ff8089604c8 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1290
13 AppKit 0x7ff807f34eb7 -[NSApplication run] + 610
14 VirtualDJ 0x100dc5307 main + 476
15 dyld 0x209f102cd start + 1805
Thread 1:: com.apple.rosetta.exceptionserver
0 runtime 0x7ff7ffcafea0 0x7ff7ffcac000 + 16032
Thread 2:
0 runtime 0x7ff7ffcce954 0x7ff7ffcac000 + 141652
Thread 3:
Thread 4:
Thread 5:
5 Breakpad 0x11c100e6c google_breakpad::ExceptionHandler::WaitForMessage(void*) + 128
6 libsystem_pthread.dylib 0x7ff8045c3253 _pthread_start + 99
7 libsystem_pthread.dylib 0x7ff8045bebef thread_start + 15
Thread 6:: deck
1 libsystem_kernel.dylib 0x7ff8045849aa __psynch_cvwait + 10
2 libsystem_pthread.dylib 0x7ff8045c37a8 _pthread_cond_wait + 1193
3 VirtualDJ 0x100ed2a25 CThreadEvent::wait(int) + 231
4 VirtualDJ 0x100c71235 IThread::threadProc() + 71
5 VirtualDJ 0x100c711e9 IThread::staticThreadProc(void*) + 9
Thread 7:: Internet
Thread 8:: com.apple.NSEventThread
8 AppKit 0x7ff808099d6d _NSEventThread + 127
9 libsystem_pthread.dylib 0x7ff8045c3253 _pthread_start + 99
10 libsystem_pthread.dylib 0x7ff8045bebef thread_start + 15
Thread 9:: analyze
Thread 10:: caulk.messenger.shared:17
1 libsystem_kernel.dylib 0x7ff804581d8a semaphore_wait_trap + 10
2 caulk 0x7ff80fc9bcf1 caulk::semaphore::timed_wait(double) + 151
3 caulk 0x7ff80fc9bc1c caulk::concurrent::details::worker_thread::run() + 30
4 caulk 0x7ff80fc9b95e void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*>>>(void*) + 41
5 libsystem_pthread.dylib 0x7ff8045c3253 _pthread_start + 99
6 libsystem_pthread.dylib 0x7ff8045bebef thread_start + 15
Thread 11:: caulk.messenger.shared:high
Thread 12:: CloudDrive
Thread 13:: com.apple.audio.IOThread.client
1 libsystem_kernel.dylib 0x7ff804581d96 semaphore_wait_signal_trap + 10
2 caulk 0x7ff80fcb5315 caulk::mach::semaphore::wait_signal_or_error(caulk::mach::semaphore&) + 23
3 CoreAudio 0x7ff806ea4861 HALC_ProxyIOContext::IOWorkLoop() + 5515
4 CoreAudio 0x7ff806ea2ad8 invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int) + 148
5 CoreAudio 0x7ff807050041 HALC_IOThread::Entry(void*) + 73
Thread 14:: tagEngine
Thread 15:: worker
1 libsystem_kernel.dylib 0x7ff804584876 __semwait_signal + 10
2 libsystem_c.dylib 0x7ff804472cf1 nanosleep + 199
3 libsystem_c.dylib 0x7ff804472c24 usleep + 53
4 VirtualDJ 0x101494baa std::__1::__function::__func<CFavoriteFolder::CFavoriteFolder(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>, int)::$_0, std::__1::allocator<CFavoriteFolder::CFavoriteFolder(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>, int)::$_0>, void (bool volatile*, float*)>::operator()(bool volatile*&&, float*&&) + 48
5 VirtualDJ 0x100dfcc4b std::__1::function<void (char const*, unsigned long)>::operator()(char const*, unsigned long) const + 39
6 VirtualDJ 0x10149a500 CWorkerThread::handleTask() + 56
7 VirtualDJ 0x101499d29 CWorkerThread::thread() + 143
8 VirtualDJ 0x100c71226 IThread::threadProc() + 56
9 VirtualDJ 0x100c711e9 IThread::staticThreadProc(void*) + 9
10 libsystem_pthread.dylib 0x7ff8045c3253 _pthread_start + 99
11 libsystem_pthread.dylib 0x7ff8045bebef thread_start + 15
Thread 16:: worker
Thread 17 Crashed:: worker
0 libsystem_platform.dylib 0x7ff8045f59f2 _platform_strlen + 18
1 VirtualDJ 0x1014e5c49 std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>::basic_string[abi:ne180100]<0>(char const*) + 25
2 VirtualDJ 0x10142e192 CRekordBoxFolder::getChildren(std::__1::vector<IFolder*, std::__1::allocator<IFolder*>>&) + 534
3 VirtualDJ 0x100e70a2c IFolder::updateChildren() + 40
4 VirtualDJ 0x100dcd06c CSelectFolderTask::handleTask(bool volatile*, float*) + 3088
5 VirtualDJ 0x10149a500 CWorkerThread::handleTask() + 56
6 VirtualDJ 0x101499d29 CWorkerThread::thread() + 143
7 VirtualDJ 0x100c71226 IThread::threadProc() + 56
8 VirtualDJ 0x100c711e9 IThread::staticThreadProc(void*) + 9
Thread 18:: browser
3 VirtualDJ 0x100ed2a60 CThreadEvent::wait(int) + 290
Thread 19:: CVDisplayLink
2 libsystem_pthread.dylib 0x7ff8045c37d9 _pthread_cond_wait + 1242
3 CoreVideo 0x7ff80e10bce5 CVDisplayLink::waitUntil(unsigned long long) + 375
4 CoreVideo 0x7ff80e10ac5e CVDisplayLink::runIOThread() + 526
Thread 20:
5 CoreMIDI 0x7ff8210901f4 XServerMachPort::ReceiveMessage(int&, void*, int&) + 98
6 CoreMIDI 0x7ff8210b08d0 MIDIProcess::MIDIInPortThread::Run() + 104
7 CoreMIDI 0x7ff8210a6674 CADeprecated::XThread::RunHelper(void*) + 10
8 CoreMIDI 0x7ff8210b0043 CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*) + 77
Thread 21:
Thread 17 crashed with X86 Thread State (64-bit):
rax: 0x000000030f437c19 rbx: 0x000000030f437be8 rcx: 0x0000000000000000 rdx: 0x0000000000000000
rdi: 0x0000000000000000 rsi: 0x0000000000000000 rbp: 0x000000030f437b90 rsp: 0x000000030f437b90
r8: 0x000000000000003a r9: 0x00000000ffffffe0 r10: 0x0000000000001fff r11: 0x0000000000000000
r12: 0x000000030f437c19 r13: 0x000000000000000a r14: 0x000000030f437d40 r15: 0x0000000000000000
rip: <unavailable> rfl: 0x0000000000000246
tmp0: 0x00007ff894c9ea50 tmp1: 0x0000000110f12ce0 tmp2: 0x00007ff8045f59e0
Binary Images:
0x209f0a000 - 0x209f96fff dyld (*) <69c73748-37ae-3a6f-83af-690645c3da75> /usr/lib/dyld
0x7ff7ffcac000 - 0x7ff7ffcdbfff runtime (*) <e447ba6f-c0b7-3dcb-b110-b38e57558dc3> /usr/libexec/rosetta/runtime
0x11bb56000 - 0x11bbbdfff libRosettaRuntime (*) <4cb71c5f-4e41-3ce6-a65a-b283bc4bfab5> /Library/Apple/*/libRosettaRuntime
0x100c4b000 - 0x106093fff com.atomixproductions.virtualdj (8.5.8346) <ebdb16ff-4d9c-3d89-9410-7e80070dcf78> /Applications/VirtualDJ.app/Contents/MacOS/VirtualDJ
0x11d368000 - 0x11dff7fff ml113.dylib (*) <bdadc8ef-c879-3143-9de0-fbde86019091> /Applications/VirtualDJ.app/Contents/Frameworks/ml113.dylib
0x11c0fe000 - 0x11c109fff com.googlecode.google-breakpad (*) <6462e565-d5c5-3a39-92c9-70e0a540ec87> /Applications/VirtualDJ.app/Contents/Frameworks/Breakpad.framework/Versions/A/Breakpad
0x11c18c000 - 0x11c19bfff breakpadUtilities.dylib (*) <23580e48-d30f-321f-b058-1d501afcccab> /Applications/VirtualDJ.app/Contents/Frameworks/Breakpad.framework/Versions/A/Resources/breakpadUtilities.dylib
0x11d2f2000 - 0x11d2fefff libobjc-trampolines.dylib (*) <7f101600-57f3-3aaf-8f85-2195348c1912> /usr/lib/libobjc-trampolines.dylib
0x127c61000 - 0x1284c2fff com.apple.AGXMetalG15G-C0 (320.35.5) <d4c4cc07-1bfb-3756-8574-ee6d5520bdf6> /System/Library/Extensions/AGXMetalG15G_C0.bundle/Contents/MacOS/AGXMetalG15G_C0
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x7ff804581000 - 0x7ff8045bcfff libsystem_kernel.dylib (*) <10094a6c-fa57-367f-b06e-7c449ea31285> /usr/lib/system/libsystem_kernel.dylib
0x7ff80462c000 - 0x7ff804acaff2 com.apple.CoreFoundation (6.9) <8d3ca9b4-682e-3a08-b01b-4413326f47aa> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff81008e000 - 0x7ff810369ff4 com.apple.HIToolbox (2.1.1) <98a58f35-29b9-32ce-b1ba-5bde0bfe5ae2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7ff807f04000 - 0x7ff80939effd com.apple.AppKit (6.9) <3965bcfd-1388-392c-9984-fdf5a732b256> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7ff8045bd000 - 0x7ff8045c8fff libsystem_pthread.dylib (*) <c0db9cf9-86ec-31d4-a557-2c07945fd8f2> /usr/lib/system/libsystem_pthread.dylib
0x7ff80fc9a000 - 0x7ff80fcbdfff com.apple.audio.caulk (1.0) <09fe8d44-b9ca-35bf-ab5b-ddb42f62fee0> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x7ff806cbd000 - 0x7ff8073fbfff com.apple.audio.CoreAudio (5.0) <d3a27106-6ae2-354d-9402-56d6e05f8589> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7ff804463000 - 0x7ff8044ebff7 libsystem_c.dylib (*) <2d4e63ef-e31c-3cc1-94ec-2b7e28b9782f> /usr/lib/system/libsystem_c.dylib
0x7ff8045f4000 - 0x7ff8045fdfff libsystem_platform.dylib (*) <2568a05f-3db8-3b09-9ea2-aaf2fc264a52> /usr/lib/system/libsystem_platform.dylib
0x7ff80e108000 - 0x7ff80e15bff3 com.apple.CoreVideo (1.8) <c07bd761-b2b4-351e-8793-f18b0ad28f2a> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7ff821055000 - 0x7ff821104fff com.apple.audio.midi.CoreMIDI (2.0) <a7669c28-e3e8-3389-81fb-f0a5b8a64673> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)
Writable regions: Total=807.7M written=2297K(0%) resident=2297K(0%) swapped_out=0K(0%) unallocated=805.5M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 256K 1
ColorSync 236K 26
CoreAnimation 168K 12
CoreGraphics 12K 2
CoreServices 240K 1
Dispatch continuations 64.0M 1
Foundation 16K 1
Kernel Alloc Once 8K 1
MALLOC 524.3M 355
MALLOC guard page 288K 18
MALLOC_LARGE (reserved) 16.0M 1 reserved VM address space (unallocated)
Mach message 8K 2
Rosetta Arena 4096K 2
Rosetta Generic 1656K 411
Rosetta IndirectBranch 1024K 1
Rosetta JIT 128.0M 1
Rosetta Return Stack 420K 42
Rosetta Thread Context 420K 42
STACK GUARD 16K 4
Stack 18.2M 21
Stack Guard 56.1M 17
VM_ALLOCATE 280K 23
VM_ALLOCATE (reserved) 40K 3 reserved VM address space (unallocated)
__CTF 824 1
__DATA 53.2M 881
__DATA_CONST 89.4M 890
__DATA_DIRTY 2581K 338
__FONT_DATA 2352 1
__INFO_FILTER 8 1
__LINKEDIT 237.7M 14
__OBJC_RO 76.1M 1
__OBJC_RW 2351K 2
__TEXT 1.1G 911
__TPRO_CONST 280K 2
mapped file 401.5M 45
owned unmapped memory 176K 1
page table in kernel 2297K 1
shared memory 900K 15
TOTAL 2.7G 4092
TOTAL, minus reserved VM space 2.7G 4092
Full Report
{"app_name":"VirtualDJ","timestamp":"2024-11-01 00:05:43.00 +0100","app_version":"8.5.8346","slice_uuid":"ebdb16ff-4d9c-3d89-9410-7e80070dcf78","build_version":"18.0.8350","platform":1,"bundleID":"com.atomixproductions.virtualdj","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 15.0.1 (24A348)","roots_installed":0,"name":"VirtualDJ","incident_id":"020F8023-C67E-4E8D-9322-4D13AB0C2DF8"}
"uptime" : 780,
"procRole" : "Background",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "Mac15,13",
"coalitionID" : 1262,
"osVersion" : {
"train" : "macOS 15.0.1",
"build" : "24A348",
"releaseType" : "User"
"captureTime" : "2024-11-01 00:05:41.2218 +0100",
"codeSigningMonitor" : 1,
"incident" : "020F8023-C67E-4E8D-9322-4D13AB0C2DF8",
"pid" : 1271,
"translated" : true,
"cpuType" : "X86-64",
"roots_installed" : 0,
"bug_type" : "309",
"procLaunch" : "2024-11-01 00:05:39.0312 +0100",
"procStartAbsTime" : 18793598676,
"procExitAbsTime" : 18845911797,
"procName" : "VirtualDJ",
"procPath" : "\/Applications\/VirtualDJ.app\/Contents\/MacOS\/VirtualDJ",
"bundleInfo" : {"CFBundleShortVersionString":"8.5.8346","CFBundleVersion":"18.0.8350","CFBundleIdentifier":"com.atomixproductions.virtualdj"},
"storeInfo" : {"deviceIdentifierForVendor":"8BFFEC27-9656-592E-99B0-8C94DC100700","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.atomixproductions.virtualdj",
"crashReporterKey" : "017175E1-DF91-BAE8-B71E-66A2AEB85F21",
"lowPowerMode" : 1,
"responsiblePid" : 1267,
"codeSigningID" : "com.atomixproductions.virtualdj",
"codeSigningTeamID" : "CXH2B5N5M8",
"codeSigningFlags" : 570491649,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 4294967295,
"bootSessionUUID" : "E7BD04E1-8D76-403A-AEEC-D3751826C568",
"sleepWakeUUID" : "3A766DB3-0066-4A5F-9049-8F357A81AC0F",
"sip" : "enabled",
"vmRegionInfo" : "0 is not in any region. Bytes before following region: 4307857408\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 100c4b000-106094000 [ 84.3M] r-x\/r-x SM=COW \/Applications\/VirtualDJ.app\/Contents\/MacOS\/VirtualDJ",
"exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":1271},
"vmregioninfo" : "0 is not in any region. Bytes before following region: 4307857408\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 100c4b000-106094000 [ 84.3M] r-x\/r-x SM=COW \/Applications\/VirtualDJ.app\/Contents\/MacOS\/VirtualDJ",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 17,
"threads" : [{"id":22361,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":41794326757376},"r12":{"value":4294967295},"rosetta":{"tmp2":{"value":140703201560098},"tmp1":{"value":140705619340148},"tmp0":{"value":18446744073709551615}},"rbx":{"value":41794326757376},"r8":{"value":0},"r15":{"value":41794326757376},"r10":{"value":41794326757376},"rdx":{"value":8589934592},"rdi":{"value":4294967295},"r9":{"value":41794326757376},"r13":{"value":21592279046},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":21592279046},"r14":{"value":2},"rsi":{"value":2}},"queue":"com.apple.main-thread","frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":3598,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":10},{"imageOffset":63010,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":10},{"imageOffset":32534,"symbol":"mach_msg_overwrite","symbolLocation":649,"imageIndex":10},{"imageOffset":4351,"symbol":"mach_msg","symbolLocation":19,"imageIndex":10},{"imageOffset":512931,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":143,"imageIndex":11},{"imageOffset":507403,"symbol":"__CFRunLoopRun","symbolLocation":1393,"imageIndex":11},{"imageOffset":504490,"symbol":"CFRunLoopRunSpecific","symbolLocation":536,"imageIndex":11},{"imageOffset":978915,"symbol":"RunCurrentEventLoopInMode","symbolLocation":292,"imageIndex":12},{"imageOffset":1001924,"symbol":"ReceiveNextEventCommon","symbolLocation":646,"imageIndex":12},{"imageOffset":1002338,"symbol":"_BlockUntilNextEventMatchingListInModeWithFilter","symbolLocation":66,"imageIndex":12},{"imageOffset":261515,"symbol":"_DPSNextEvent","symbolLocation":902,"imageIndex":13},{"imageOffset":10863816,"symbol":"-[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]","symbolLocation":1290,"imageIndex":13},{"imageOffset":200375,"symbol":"-[NSApplication run]","symbolLocation":610,"imageIndex":13},{"imageOffset":1549063,"symbol":"main","symbolLocation":476,"imageIndex":3},{"imageOffset":25293,"symbol":"start","symbolLocation":1805,"imageIndex":0}]},{"id":22366,"name":"com.apple.rosetta.exceptionserver","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":9908489551872},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":533310384111616},"tmp0":{"value":10741713207296}},"rbx":{"value":533310384111616},"r8":{"value":2307},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":4784963584},"r13":{"value":0},"rflags":{"value":582},"rax":{"value":268451845},"rsp":{"value":10741713207296},"r11":{"value":0},"rcx":{"value":17314086914},"r14":{"value":0},"rsi":{"value":2616}},"frames":[{"imageOffset":16032,"imageIndex":1}]},{"id":22367,"frames":[{"imageOffset":141652,"imageIndex":1}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13132894208},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13133430784},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":4867},"r14":{"value":0},"rsi":{"value":0}}},{"id":22368,"frames":[{"imageOffset":141652,"imageIndex":1}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13133451264},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13133987840},"rsp":{"value":409603},"r11":{"value":0},"rcx":{"value":9219},"r14":{"value":0},"rsi":{"value":0}}},{"id":22369,"frames":[{"imageOffset":141652,"imageIndex":1}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13134008320},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13134544896},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":31499},"r14":{"value":0},"rsi":{"value":0}}},{"id":22370,"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":3598,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":10},{"imageOffset":63010,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":10},{"imageOffset":32534,"symbol":"mach_msg_overwrite","symbolLocation":649,"imageIndex":10},{"imageOffset":4351,"symbol":"mach_msg","symbolLocation":19,"imageIndex":10},{"imageOffset":11884,"symbol":"google_breakpad::ExceptionHandler::WaitForMessage(void*)","symbolLocation":128,"imageIndex":5},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":145148419768320},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703201560098},"tmp1":{"value":140705619340148},"tmp0":{"value":18446744073709551615}},"rbx":{"value":145148419894799},"r8":{"value":10312216477696},"r15":{"value":145148419768320},"r10":{"value":145148419894799},"rdx":{"value":2147488018},"rdi":{"value":0},"r9":{"value":145148419768320},"r13":{"value":17179869190},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":10312216477696},"r11":{"value":588},"rcx":{"value":17179869190},"r14":{"value":588},"rsi":{"value":588}}},{"id":22372,"name":"deck","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":999998000},"rosetta":{"tmp2":{"value":140703201511840},"tmp1":{"value":140705619339864},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703201776233,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":999998000},"r9":{"value":160},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13135618048},"rsi":{"value":9}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":14762,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":10},{"imageOffset":26536,"symbol":"_pthread_cond_wait","symbolLocation":1193,"imageIndex":14},{"imageOffset":2652709,"symbol":"CThreadEvent::wait(int)","symbolLocation":231,"imageIndex":3},{"imageOffset":156213,"symbol":"IThread::threadProc()","symbolLocation":71,"imageIndex":3},{"imageOffset":156137,"symbol":"IThread::staticThreadProc(void*)","symbolLocation":9,"imageIndex":3},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22378,"name":"Internet","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":999999000},"rosetta":{"tmp2":{"value":140703201511840},"tmp1":{"value":140705619339864},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703201776233,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":512},"r10":{"value":0},"rdx":{"value":512},"rdi":{"value":999999000},"r9":{"value":160},"r13":{"value":2203318223616},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13138837504},"rsi":{"value":0}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":14762,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":10},{"imageOffset":26536,"symbol":"_pthread_cond_wait","symbolLocation":1193,"imageIndex":14},{"imageOffset":2652709,"symbol":"CThreadEvent::wait(int)","symbolLocation":231,"imageIndex":3},{"imageOffset":156213,"symbol":"IThread::threadProc()","symbolLocation":71,"imageIndex":3},{"imageOffset":156137,"symbol":"IThread::staticThreadProc(void*)","symbolLocation":9,"imageIndex":3},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22381,"name":"com.apple.NSEventThread","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":195725954646016},"r12":{"value":4294967295},"rosetta":{"tmp2":{"value":140703201560098},"tmp1":{"value":140705619340148},"tmp0":{"value":18446744073709551615}},"rbx":{"value":195725954646016},"r8":{"value":0},"r15":{"value":195725954646016},"r10":{"value":195725954646016},"rdx":{"value":8589934592},"rdi":{"value":4294967295},"r9":{"value":195725954646016},"r13":{"value":21592279046},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":21592279046},"r14":{"value":2},"rsi":{"value":2}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":3598,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":10},{"imageOffset":63010,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":10},{"imageOffset":32534,"symbol":"mach_msg_overwrite","symbolLocation":649,"imageIndex":10},{"imageOffset":4351,"symbol":"mach_msg","symbolLocation":19,"imageIndex":10},{"imageOffset":512931,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":143,"imageIndex":11},{"imageOffset":507403,"symbol":"__CFRunLoopRun","symbolLocation":1393,"imageIndex":11},{"imageOffset":504490,"symbol":"CFRunLoopRunSpecific","symbolLocation":536,"imageIndex":11},{"imageOffset":1662317,"symbol":"_NSEventThread","symbolLocation":127,"imageIndex":13},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22383,"name":"analyze","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703201511840},"tmp1":{"value":140705619339864},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703201776233,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":7424},"r10":{"value":0},"rdx":{"value":7424},"rdi":{"value":0},"r9":{"value":160},"r13":{"value":31890132180480},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":1099511628032},"rcx":{"value":0},"r14":{"value":13137764352},"rsi":{"value":2}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":14762,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":10},{"imageOffset":26536,"symbol":"_pthread_cond_wait","symbolLocation":1193,"imageIndex":14},{"imageOffset":2652709,"symbol":"CThreadEvent::wait(int)","symbolLocation":231,"imageIndex":3},{"imageOffset":156213,"symbol":"IThread::threadProc()","symbolLocation":71,"imageIndex":3},{"imageOffset":156137,"symbol":"IThread::staticThreadProc(void*)","symbolLocation":9,"imageIndex":3},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22388,"name":"caulk.messenger.shared:17","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":25},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703201510405},"tmp1":{"value":140705619339860},"tmp0":{"value":18446744073709551615}},"rbx":{"value":13157236842},"r8":{"value":140380248771760},"r15":{"value":0},"r10":{"value":13157236842},"rdx":{"value":0},"rdi":{"value":140380248771728},"r9":{"value":25},"r13":{"value":0},"rflags":{"value":663},"rax":{"value":14},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":140380248768570},"r14":{"value":140380248771760},"rsi":{"value":140703393496062,"symbolLocation":0,"symbol":"caulk::concurrent::details::worker_thread::run()"}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":3466,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":10},{"imageOffset":7409,"symbol":"caulk::semaphore::timed_wait(double)","symbolLocation":151,"imageIndex":15},{"imageOffset":7196,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":30,"imageIndex":15},{"imageOffset":6494,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*>>>(void*)","symbolLocation":41,"imageIndex":15},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22389,"name":"caulk.messenger.shared:high","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":27},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703201510405},"tmp1":{"value":140705619339860},"tmp0":{"value":18446744073709551615}},"rbx":{"value":13157773420},"r8":{"value":140380248777776},"r15":{"value":0},"r10":{"value":13157773420},"rdx":{"value":0},"rdi":{"value":140380248777744},"r9":{"value":27},"r13":{"value":0},"rflags":{"value":663},"rax":{"value":14},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":140380238504172},"r14":{"value":140380248777776},"rsi":{"value":140703393496062,"symbolLocation":0,"symbol":"caulk::concurrent::details::worker_thread::run()"}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":3466,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":10},{"imageOffset":7409,"symbol":"caulk::semaphore::timed_wait(double)","symbolLocation":151,"imageIndex":15},{"imageOffset":7196,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":30,"imageIndex":15},{"imageOffset":6494,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*>>>(void*)","symbolLocation":41,"imageIndex":15},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22393,"name":"CloudDrive","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":999999000},"rosetta":{"tmp2":{"value":140703201511840},"tmp1":{"value":140705619339864},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703201776233,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":256},"r10":{"value":0},"rdx":{"value":256},"rdi":{"value":999999000},"r9":{"value":160},"r13":{"value":2203318223616},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13158846464},"rsi":{"value":0}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":14762,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":10},{"imageOffset":26536,"symbol":"_pthread_cond_wait","symbolLocation":1193,"imageIndex":14},{"imageOffset":2652709,"symbol":"CThreadEvent::wait(int)","symbolLocation":231,"imageIndex":3},{"imageOffset":156213,"symbol":"IThread::threadProc()","symbolLocation":71,"imageIndex":3},{"imageOffset":156137,"symbol":"IThread::staticThreadProc(void*)","symbolLocation":9,"imageIndex":3},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22398,"name":"com.apple.audio.IOThread.client","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":39599375},"r12":{"value":140380754534912},"rosetta":{"tmp2":{"value":140703201561306},"tmp1":{"value":140705619339860},"tmp0":{"value":18446744073709551615}},"rbx":{"value":140380754534968},"r8":{"value":13159382800},"r15":{"value":1},"r10":{"value":140380754534968},"rdx":{"value":2199023256064},"rdi":{"value":140380281563808},"r9":{"value":39599375},"r13":{"value":0},"rflags":{"value":663},"rax":{"value":14},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":79363},"r14":{"value":140380754535192},"rsi":{"value":140380266222512}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":3478,"symbol":"semaphore_wait_signal_trap","symbolLocation":10,"imageIndex":10},{"imageOffset":111381,"symbol":"caulk::mach::semaphore::wait_signal_or_error(caulk::mach::semaphore&)","symbolLocation":23,"imageIndex":15},{"imageOffset":1996897,"symbol":"HALC_ProxyIOContext::IOWorkLoop()","symbolLocation":5515,"imageIndex":16},{"imageOffset":1989336,"symbol":"invocation function for block in HALC_ProxyIOContext::HALC_ProxyIOContext(unsigned int, unsigned int)","symbolLocation":148,"imageIndex":16},{"imageOffset":3747905,"symbol":"HALC_IOThread::Entry(void*)","symbolLocation":73,"imageIndex":16},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22403,"name":"tagEngine","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703201511840},"tmp1":{"value":140705619339864},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703201776233,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":160},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13138300928},"rsi":{"value":1}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":14762,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":10},{"imageOffset":26536,"symbol":"_pthread_cond_wait","symbolLocation":1193,"imageIndex":14},{"imageOffset":2652709,"symbol":"CThreadEvent::wait(int)","symbolLocation":231,"imageIndex":3},{"imageOffset":156213,"symbol":"IThread::threadProc()","symbolLocation":71,"imageIndex":3},{"imageOffset":156137,"symbol":"IThread::staticThreadProc(void*)","symbolLocation":9,"imageIndex":3},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22404,"name":"worker","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":100000000},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703201511532},"tmp1":{"value":140705619339864},"tmp0":{"value":18446744073709551615}},"rbx":{"value":1},"r8":{"value":13139373696},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":{"value":8},"r9":{"value":100000000},"r13":{"value":0},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13139373616},"rsi":{"value":4765577344}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":14454,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":10},{"imageOffset":64753,"symbol":"nanosleep","symbolLocation":199,"imageIndex":17},{"imageOffset":64548,"symbol":"usleep","symbolLocation":53,"imageIndex":17},{"imageOffset":8690602,"symbol":"std::__1::__function::__func<CFavoriteFolder::CFavoriteFolder(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>, int)::$_0, std::__1::allocator<CFavoriteFolder::CFavoriteFolder(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>, int)::$_0>, void (bool volatile*, float*)>::operator()(bool volatile*&&, float*&&)","symbolLocation":48,"imageIndex":3},{"imageOffset":1776715,"symbol":"std::__1::function<void (char const*, unsigned long)>::operator()(char const*, unsigned long) const","symbolLocation":39,"imageIndex":3},{"imageOffset":8713472,"symbol":"CWorkerThread::handleTask()","symbolLocation":56,"imageIndex":3},{"imageOffset":8711465,"symbol":"CWorkerThread::thread()","symbolLocation":143,"imageIndex":3},{"imageOffset":156198,"symbol":"IThread::threadProc()","symbolLocation":56,"imageIndex":3},{"imageOffset":156137,"symbol":"IThread::staticThreadProc(void*)","symbolLocation":9,"imageIndex":3},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22405,"name":"worker","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":100000000},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703201511532},"tmp1":{"value":140705619339864},"tmp0":{"value":18446744073709551615}},"rbx":{"value":1},"r8":{"value":13139910272},"r15":{"value":0},"r10":{"value":1},"rdx":{"value":1},"rdi":{"value":4},"r9":{"value":100000000},"r13":{"value":0},"rflags":{"value":646},"rax":{"value":4},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13139910192},"rsi":{"value":4765577344}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":14454,"symbol":"__semwait_signal","symbolLocation":10,"imageIndex":10},{"imageOffset":64753,"symbol":"nanosleep","symbolLocation":199,"imageIndex":17},{"imageOffset":64548,"symbol":"usleep","symbolLocation":53,"imageIndex":17},{"imageOffset":8690602,"symbol":"std::__1::__function::__func<CFavoriteFolder::CFavoriteFolder(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>, int)::$_0, std::__1::allocator<CFavoriteFolder::CFavoriteFolder(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>, int)::$_0>, void (bool volatile*, float*)>::operator()(bool volatile*&&, float*&&)","symbolLocation":48,"imageIndex":3},{"imageOffset":1776715,"symbol":"std::__1::function<void (char const*, unsigned long)>::operator()(char const*, unsigned long) const","symbolLocation":39,"imageIndex":3},{"imageOffset":8713472,"symbol":"CWorkerThread::handleTask()","symbolLocation":56,"imageIndex":3},{"imageOffset":8711465,"symbol":"CWorkerThread::thread()","symbolLocation":143,"imageIndex":3},{"imageOffset":156198,"symbol":"IThread::threadProc()","symbolLocation":56,"imageIndex":3},{"imageOffset":156137,"symbol":"IThread::staticThreadProc(void*)","symbolLocation":9,"imageIndex":3},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"triggered":true,"id":22407,"name":"worker","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13140982672},"r12":{"value":13140982809},"rosetta":{"tmp2":{"value":140703201974752},"tmp1":{"value":4579208416},"tmp0":{"value":140705624877648}},"rbx":{"value":13140982760},"r8":{"value":58},"r15":{"value":0},"r10":{"value":8191},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":4294967264},"r13":{"value":10},"rflags":{"value":582},"rax":{"value":13140982809},"rsp":{"value":13140982672},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13140983104},"rsi":{"value":0}},"frames":[{"imageOffset":6642,"symbol":"_platform_strlen","symbolLocation":18,"imageIndex":18},{"imageOffset":9022537,"symbol":"std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char>>::basic_string[abi:ne180100]<0>(char const*)","symbolLocation":25,"imageIndex":3},{"imageOffset":8270226,"symbol":"CRekordBoxFolder::getChildren(std::__1::vector<IFolder*, std::__1::allocator<IFolder*>>&)","symbolLocation":534,"imageIndex":3},{"imageOffset":2251308,"symbol":"IFolder::updateChildren()","symbolLocation":40,"imageIndex":3},{"imageOffset":1581164,"symbol":"CSelectFolderTask::handleTask(bool volatile*, float*)","symbolLocation":3088,"imageIndex":3},{"imageOffset":8713472,"symbol":"CWorkerThread::handleTask()","symbolLocation":56,"imageIndex":3},{"imageOffset":8711465,"symbol":"CWorkerThread::thread()","symbolLocation":143,"imageIndex":3},{"imageOffset":156198,"symbol":"IThread::threadProc()","symbolLocation":56,"imageIndex":3},{"imageOffset":156137,"symbol":"IThread::staticThreadProc(void*)","symbolLocation":9,"imageIndex":3},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22410,"name":"browser","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":160},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703201511840},"tmp1":{"value":140705619339864},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":140703201776233,"symbolLocation":0,"symbol":"_pthread_psynch_cond_cleanup"},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":160},"r13":{"value":4294967552},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":13142593536},"rsi":{"value":0}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":14762,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":10},{"imageOffset":26536,"symbol":"_pthread_cond_wait","symbolLocation":1193,"imageIndex":14},{"imageOffset":2652768,"symbol":"CThreadEvent::wait(int)","symbolLocation":290,"imageIndex":3},{"imageOffset":156213,"symbol":"IThread::threadProc()","symbolLocation":71,"imageIndex":3},{"imageOffset":156137,"symbol":"IThread::staticThreadProc(void*)","symbolLocation":9,"imageIndex":3},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22412,"name":"CVDisplayLink","threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":65704},"r12":{"value":9873364},"rosetta":{"tmp2":{"value":140703201511840},"tmp1":{"value":140705619339864},"tmp0":{"value":18446744073709551615}},"rbx":{"value":0},"r8":{"value":784978910333},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":0},"rdi":{"value":9873364},"r9":{"value":65704},"r13":{"value":14297946131968},"rflags":{"value":658},"rax":{"value":260},"rsp":{"value":0},"r11":{"value":0},"rcx":{"value":0},"r14":{"value":3584},"rsi":{"value":0}},"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":14762,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":10},{"imageOffset":26585,"symbol":"_pthread_cond_wait","symbolLocation":1242,"imageIndex":14},{"imageOffset":15589,"symbol":"CVDisplayLink::waitUntil(unsigned long long)","symbolLocation":375,"imageIndex":19},{"imageOffset":11358,"symbol":"CVDisplayLink::runIOThread()","symbolLocation":526,"imageIndex":19},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}]},{"id":22415,"frames":[{"imageOffset":140705619339908,"imageIndex":9},{"imageOffset":3598,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":10},{"imageOffset":63010,"symbol":"mach_msg2_internal","symbolLocation":84,"imageIndex":10},{"imageOffset":32534,"symbol":"mach_msg_overwrite","symbolLocation":649,"imageIndex":10},{"imageOffset":4351,"symbol":"mach_msg","symbolLocation":19,"imageIndex":10},{"imageOffset":242164,"symbol":"XServerMachPort::ReceiveMessage(int&, void*, int&)","symbolLocation":98,"imageIndex":20},{"imageOffset":374992,"symbol":"MIDIProcess::MIDIInPortThread::Run()","symbolLocation":104,"imageIndex":20},{"imageOffset":333428,"symbol":"CADeprecated::XThread::RunHelper(void*)","symbolLocation":10,"imageIndex":20},{"imageOffset":372803,"symbol":"CADeprecated::CAPThread::Entry(CADeprecated::CAPThread*)","symbolLocation":77,"imageIndex":20},{"imageOffset":25171,"symbol":"_pthread_start","symbolLocation":99,"imageIndex":14},{"imageOffset":7151,"symbol":"thread_start","symbolLocation":15,"imageIndex":14}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":550885390286848},"r12":{"value":0},"rosetta":{"tmp2":{"value":140703201560098},"tmp1":{"value":140705619340148},"tmp0":{"value":18446744073709551615}},"rbx":{"value":550885390286848},"r8":{"value":0},"r15":{"value":550885390286848},"r10":{"value":550885390286848},"rdx":{"value":0},"rdi":{"value":0},"r9":{"value":550885390286848},"r13":{"value":17179869186},"rflags":{"value":643},"rax":{"value":268451845},"rsp":{"value":0},"r11":{"value":100},"rcx":{"value":17179869186},"r14":{"value":100},"rsi":{"value":100}}},{"id":22417,"frames":[{"imageOffset":141652,"imageIndex":1}],"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":18446744073709551615},"r12":{"value":0},"rosetta":{"tmp2":{"value":0},"tmp1":{"value":0},"tmp0":{"value":0}},"rbx":{"value":0},"r8":{"value":0},"r15":{"value":0},"r10":{"value":0},"rdx":{"value":13141004288},"rdi":{"value":0},"r9":{"value":0},"r13":{"value":0},"rflags":{"value":531},"rax":{"value":13141540864},"rsp":{"value":409604},"r11":{"value":0},"rcx":{"value":125231},"r14":{"value":0},"rsi":{"value":0}}}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 8756699136,
"size" : 577536,
"uuid" : "69c73748-37ae-3a6f-83af-690645c3da75",
"path" : "\/usr\/lib\/dyld",
"name" : "dyld"
"source" : "P",
"arch" : "arm64",
"base" : 140703125127168,
"size" : 196608,
"uuid" : "e447ba6f-c0b7-3dcb-b110-b38e57558dc3",
"path" : "\/usr\/libexec\/rosetta\/runtime",
"name" : "runtime"
"source" : "P",
"arch" : "arm64",
"base" : 4759838720,
"size" : 425984,
"uuid" : "4cb71c5f-4e41-3ce6-a65a-b283bc4bfab5",
"path" : "\/Library\/Apple\/*\/libRosettaRuntime",
"name" : "libRosettaRuntime"
"source" : "P",
"arch" : "x86_64",
"base" : 4307857408,
"CFBundleShortVersionString" : "8.5.8346",
"CFBundleIdentifier" : "com.atomixproductions.virtualdj",
"size" : 88379392,
"uuid" : "ebdb16ff-4d9c-3d89-9410-7e80070dcf78",
"path" : "\/Applications\/VirtualDJ.app\/Contents\/MacOS\/VirtualDJ",
"name" : "VirtualDJ",
"CFBundleVersion" : "18.0.8350"
"source" : "P",
"arch" : "x86_64",
"base" : 4785078272,
"size" : 13172736,
"uuid" : "bdadc8ef-c879-3143-9de0-fbde86019091",
"path" : "\/Applications\/VirtualDJ.app\/Contents\/Frameworks\/ml113.dylib",
"name" : "ml113.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4765769728,
"CFBundleIdentifier" : "com.googlecode.google-breakpad",
"size" : 49152,
"uuid" : "6462e565-d5c5-3a39-92c9-70e0a540ec87",
"path" : "\/Applications\/VirtualDJ.app\/Contents\/Frameworks\/Breakpad.framework\/Versions\/A\/Breakpad",
"name" : "Breakpad",
"CFBundleVersion" : "1.0"
"source" : "P",
"arch" : "x86_64",
"base" : 4766351360,
"size" : 65536,
"uuid" : "23580e48-d30f-321f-b058-1d501afcccab",
"path" : "\/Applications\/VirtualDJ.app\/Contents\/Frameworks\/Breakpad.framework\/Versions\/A\/Resources\/breakpadUtilities.dylib",
"name" : "breakpadUtilities.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4784594944,
"size" : 53248,
"uuid" : "7f101600-57f3-3aaf-8f85-2195348c1912",
"path" : "\/usr\/lib\/libobjc-trampolines.dylib",
"name" : "libobjc-trampolines.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4962258944,
"CFBundleShortVersionString" : "320.35.5",
"CFBundleIdentifier" : "com.apple.AGXMetalG15G-C0",
"size" : 8790016,
"uuid" : "d4c4cc07-1bfb-3756-8574-ee6d5520bdf6",
"path" : "\/System\/Library\/Extensions\/AGXMetalG15G_C0.bundle\/Contents\/MacOS\/AGXMetalG15G_C0",
"name" : "AGXMetalG15G_C0",
"CFBundleVersion" : "320.35.5"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "x86_64",
"base" : 140703201497088,
"size" : 245760,
"uuid" : "10094a6c-fa57-367f-b06e-7c449ea31285",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703202197504,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 4845555,
"uuid" : "8d3ca9b4-682e-3a08-b01b-4413326f47aa",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "3038.1.403"
"source" : "P",
"arch" : "x86_64",
"base" : 140703397634048,
"CFBundleShortVersionString" : "2.1.1",
"CFBundleIdentifier" : "com.apple.HIToolbox",
"size" : 2998261,
"uuid" : "98a58f35-29b9-32ce-b1ba-5bde0bfe5ae2",
"path" : "\/System\/Library\/Frameworks\/Carbon.framework\/Versions\/A\/Frameworks\/HIToolbox.framework\/Versions\/A\/HIToolbox",
"name" : "HIToolbox"
"source" : "P",
"arch" : "x86_64",
"base" : 140703261802496,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 21606398,
"uuid" : "3965bcfd-1388-392c-9984-fdf5a732b256",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2566"
"source" : "P",
"arch" : "x86_64",
"base" : 140703201742848,
"size" : 49152,
"uuid" : "c0db9cf9-86ec-31d4-a557-2c07945fd8f2",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703393488896,
"CFBundleShortVersionString" : "1.0",
"CFBundleIdentifier" : "com.apple.audio.caulk",
"size" : 147456,
"uuid" : "09fe8d44-b9ca-35bf-ab5b-ddb42f62fee0",
"path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
"name" : "caulk"
"source" : "P",
"arch" : "x86_64",
"base" : 140703242637312,
"CFBundleShortVersionString" : "5.0",
"CFBundleIdentifier" : "com.apple.audio.CoreAudio",
"size" : 7598080,
"uuid" : "d3a27106-6ae2-354d-9402-56d6e05f8589",
"path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio",
"name" : "CoreAudio",
"CFBundleVersion" : "5.0"
"source" : "P",
"arch" : "x86_64",
"base" : 140703200325632,
"size" : 561144,
"uuid" : "2d4e63ef-e31c-3cc1-94ec-2b7e28b9782f",
"path" : "\/usr\/lib\/system\/libsystem_c.dylib",
"name" : "libsystem_c.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703201968128,
"size" : 40960,
"uuid" : "2568a05f-3db8-3b09-9ea2-aaf2fc264a52",
"path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
"name" : "libsystem_platform.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703364579328,
"CFBundleShortVersionString" : "1.8",
"CFBundleIdentifier" : "com.apple.CoreVideo",
"size" : 344052,
"uuid" : "c07bd761-b2b4-351e-8793-f18b0ad28f2a",
"path" : "\/System\/Library\/Frameworks\/CoreVideo.framework\/Versions\/A\/CoreVideo",
"name" : "CoreVideo",
"CFBundleVersion" : "648.29"
"source" : "P",
"arch" : "x86_64",
"base" : 140703682613248,
"CFBundleShortVersionString" : "2.0",
"CFBundleIdentifier" : "com.apple.audio.midi.CoreMIDI",
"size" : 720896,
"uuid" : "a7669c28-e3e8-3389-81fb-f0a5b8a64673",
"path" : "\/System\/Library\/Frameworks\/CoreMIDI.framework\/Versions\/A\/CoreMIDI",
"name" : "CoreMIDI",
"CFBundleVersion" : "88"
"sharedCache" : {
"base" : 140703197265920,
"size" : 25769803776,
"uuid" : "33b56f85-8878-3598-a926-cdd6e015ce9d"
"vmSummary" : "ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)\nWritable regions: Total=807.7M written=2297K(0%) resident=2297K(0%) swapped_out=0K(0%) unallocated=805.5M(100%)\n\n VIRTUAL REGION \nREGION TYPE
geposted Wed 06 Nov 24 @ 9:32 pm
Looks like some problem with the rekordbox library
geposted Thu 07 Nov 24 @ 4:31 am
Hi
Thanks for you answer.
In fact as i used studio.dj, i made a remix and i tried to export it to Rekoordbox and unfortunately to vdj.
I want to delete vdj and save before my xml files in order to install vdj properly.
I'm on macbook M2 16 GO sequoia 15.1.
But when i went to "user/username/" there is no files named documents/vdj. This files must be deleted
Thanks
geposted Thu 07 Nov 24 @ 5:23 pm
It looks like it’s an X86-64 build running under Rosetta..?
I thought VDJ was native Apple Silicon?
Or maybe I am misinterpreting the first lines of the crash report..
geposted Sat 09 Nov 24 @ 8:19 am
