Topic: Sync problems
Hi,
I have a denon mc6000 and when I push the sync button not much happens. The bpm changes but that's it.
But when I push the sync button with my mouse or keyboard shortcuts it's works how it should.
How do I get the sync to work on the controller like it does if I use the mouse or keyboard.
Many thanks
geposted 5 days ago @ 9:49 pm
Check the mapping to see what the button is set to.
If you don't have any custom settings you can reset it to factory default.
geposted 5 days ago @ 10:11 pm
Thanks, that is what I tried but still nothing 🤔
geposted 5 days ago @ 10:14 pm
