Topic: Is there a file size limit?
Hi. I created a set in Mp3 format which is over 2 hours long and 323 MB. It plays fine in the decks, but when I skip around to different cue points, the audio will sometimes cut out or portions of the wave will remain highlighted. Is there a limit to what the length or file size of a track should be before errors may occur? Thanks.
geposted 5 days ago @ 6:11 am
That size you're streaming from the HDD so access times come into play.
geposted 5 days ago @ 6:20 am
OK thanks guys.
geposted 5 days ago @ 11:58 am
Normally that still shouldn't take more than a few seconds to catch up though, unless there's a problem with the drive or it's very slow.
geposted 4 days ago @ 5:45 am
