Hi all,
My goal is to stems_split to any deck of my choice.
My workaround is combining stems_split and move_deck, or clone_deck [deck #], but unfortunately either breaks the "link" between the stems_split decks
I really like the linked decks feature and am trying all sorts of undocumented parameters with stems_split and stems_split_unlink to try to activate it or maintain it through moving deck.
Is there any parameter or other undocumented way to:
- stems_split to any deck other than the adjacent deck?
- maintain link through deck_move?
OR
- link two decks that haven't yet been linked with an undocumented verb or parameter?
I am knowledgeable enough about VDJScript and Skins to implement any suggested fixes. Please let me know if any of the above are currently possible.
Thanks!
OR
Thanks!
geposted Fri 15 Nov 24 @ 5:11 am
