Hi, I was hoping someone could tell me if my idea for a skin can be realized with Virtual DJ.
I know that each deck in Virtual DJ can basically have a certain number of effects. In the performance skin there are up to 3 effects per deck. These effects are per deck.
What would I like to have differently? I would like to configure 6 effects which I can then activate for the respective decks. I have tried to prepare two mock-ups to illustrate what I want.
6 Effects configured "global", not per deck:
Effect "Flanger" activated for Deck A:
I hope I was able to explain what I want. Can someone tell me if this is even possible with the Skin SDK?
geposted Fri 15 Nov 24 @ 11:11 pm
Like this?
Well not exactly like that, but similar.
You'd need to use deck 5 to hold the extra effect bank and work as master dial control for all other decks,
your way would eat 24 hardware buttons assigning to decks, my way uses only 8 an marries up with upper range controllers [2 sets of 3 fx].
geposted Sat 16 Nov 24 @ 1:00 am
That looks very promising.
geposted Sat 16 Nov 24 @ 1:17 am
I'll send you a pm.
geposted Sat 16 Nov 24 @ 1:26 am
