Hello everyone,
I'm looking for a script that allows me to scroll through the song using Shift and Jogwheels in the selected deck.
Procedure: I load a song in deck A, press Shift and turn the jogwheel and scroll in the loaded song. Like Pioneer Controllers.
Greetings and thx
Greetings and thx
geposted Sat 16 Nov 24 @ 7:06 pm
It depends on your controller, but for the most part try to remap your jog as shift ? touchwheel 'search' : touchwheel
Also you will want to remap the touch sensor of the jog to shift ? nothing : touchwheel_touch
geposted Sat 16 Nov 24 @ 9:20 pm
OK, thank you for the fast answer. For my Controller doesn't work, because it's a Rane One and have spezial Jogwheels. After a lot of time, I scripted:
Key: SHIFT_JOG
Action:
deck play ? ns7_platter : song_pos & songpos_remain
This script, works for me, if I press Shift + touch the jogwheel it scroll in the loaded deck with the new song .... (Condition deck doesn't play, if the deck with the new loaded song is playing, function is not active. Otherwise it makes no sense to me )
Key: SHIFT_JOG
Action:
geposted Sun 17 Nov 24 @ 10:57 am
Update:
Okay, I changed the "play" to "master" in the Action. Now it make no difference if the deck (where you load the new song) is playing or not. So you can needle search "on fly", very fast, in the song with shift and jogwheel. This script works only right with a 2 deck controller
geposted Mon 18 Nov 24 @ 8:55 pm
is using the script of the ns7 platter the right one for the rane one?
I'd suggest to use the platter of the rane one?!
geposted Mon 18 Nov 24 @ 10:27 pm
ns7_platter is a standard how many motorised platters talk to vdj [inMusic family so rane, numark etc]
Your masterdeck ? query, isn't just right deck, it's the masterdeck [of any decks playing the one that has the highest value from (level slider * crossfader bias) ] you just haven't poked around enough to get it on the other deck.
[there should be a name for this; default confirmation bias.... ?
I've been guilty of it ]
I'm honestly not sure you'd want to scrub the loudest deck, but... any deck at any time [since you're learning, and I think you learn best by seeing all the wrong ways as well as the one right way]
Just do this.
Just do this.
geposted Mon 18 Nov 24 @ 11:29 pm
Yes the ns7_platter are the right one...
geposted Tue 19 Nov 24 @ 12:13 am
Just do this.
Just do this.
Yes your are right, my update does not work, sorry for that....
The Problem I have, is, that if I press only Shift now by playing deck , it jumps around in the loaded song. I don't know why (Script: Just do this.
song_pos & songpos_remain) .... If the deck doesn't play and I press Shift + Jogwheel it scroll in the song....
geposted Tue 19 Nov 24 @ 12:15 am
So put it together, what would you like to do, what you can do [save values, query, do math], what you can't do, [and maybe can be done but don't know how.]
You're not going to scrub a on air deck
so
Since I mentioned it, I'd recommend looking up what get_volume does.
And future think like this, "what I want - what I can do to get close - what I don't know how to complete"
Post like that you'll get a reply every time.
so
param_equal `get_volume` 0 ? Do your thing : don't do your thing
geposted Tue 19 Nov 24 @ 2:35 am
locoDog wrote :
Just do this.
Actually the correct script here would simply be song_pos There's no need to include songpos_remain there.
PS: The best way to do this would require a more extensive remapping:
SHIFT button:
shift & up ? deck 1 var_equal 'rn1vinoff' 1 ? deck 1 set 'rn1vinoff' 0 & deck 1 vinyl_mode on : deck 2 var_equal 'rn1vinoff' 1 ? deck 2 set 'rn1vinoff' 0 & deck 2 vinyl_mode on
SHIFT_JOG:
vinyl_mode ? set 'rn1vinoff' 1 & vinyl_mode off & touchwheel 'search' : touchwheel 'search'
geposted Tue 19 Nov 24 @ 8:58 pm
THX 👍
geposted Wed 20 Nov 24 @ 10:39 pm
