I bought Hercules Inpulse 500 and my trial is running out. When i buy the license, does it mean i have VDJ free or how does that work?
geposted Sun 17 Nov 24 @ 12:09 am
when you buy the license you have the licence for hardware use,
if home+ then just the one hardware model,
if pro then any hardware that vdj supports
geposted Sun 17 Nov 24 @ 12:52 am
buy virtual dj infinity...only 350 euro
geposted Mon 18 Nov 24 @ 1:47 pm
I have an Numark party mkii controller with the home license. Should I be using Virtual Dj 2024 or 8 lite to get the best performance of the controller
geposted Wed 20 Nov 24 @ 2:28 am
hello, the performance does not change, only the type of product differs, I recommend vdj infinty, you will use it on any type of console, maximum 2 pcs
geposted Wed 20 Nov 24 @ 7:14 am
