What could be the reason for the search function in the browser to not show any results?
I'm pretty sure it's just some silly setting or so, but I can't find out what...
geposted Sat 23 Nov 24 @ 4:12 pm
One reason could be the Show Only Music/Video/Karaoke Browser Option
Another could be related to the Search Options, the fields you have selected for the Search.
geposted Sat 23 Nov 24 @ 4:23 pm
All my files are video and they all show (without using the search function). In the search options I checked all the fields I use and where search should look. So that's not it. Thanks DJDad.
BTW, it is not a problem of my skin. The default skin also doesn't show anything when I enter a letter in the search field... That's why I thought it could be a setting...
geposted Sat 23 Nov 24 @ 5:45 pm
geposted Sun 24 Nov 24 @ 2:53 pm
The files look as "New" , they have the star over the Icon, so should be in database already, but just in case, try to right-click the Folder, Batch->Add to Search DB
Is this a "real" Folder, a Filter Folder, a List (Virtual Folder), a Playlist m3u ?
geposted Sun 24 Nov 24 @ 3:00 pm
This is a real folder.
That was it, DJDad: I had to manually add the folder to the search database. Which is strange, because I have both options selected for searching in current folder and local files...
geposted Sun 24 Nov 24 @ 3:07 pm
You can set Windows locations as "watched" so VDJ adds them automatically on startup.
geposted Sun 24 Nov 24 @ 3:12 pm
Local files in this case means the entire search DB, not actual OS folders (might be a bit of a misnomer).
autoSearchDB might also be a helpful option in this case.
geposted Sun 24 Nov 24 @ 3:16 pm
Thank you both! Good tips!
geposted Sun 24 Nov 24 @ 3:28 pm
