I was doing some experimentation and noticed that both my tag and filename dupe smart folders seeming weren't working. So I intentionally copied over a file from one folder into another. Added, scanned. And no detection.
Curious if other people are having issues.
geposted Tue 10 Dec 24 @ 1:56 am
Tried the same, and it shows both here.
Depending on where you created the duplicates filter folder, maybe the scope was set to the local folder instead of database?
geposted Tue 10 Dec 24 @ 9:27 am
Given it’s the default dupe checker the scope should be the entire db.
geposted Tue 10 Dec 24 @ 11:23 am
