Hoping someone might be able to suggest something else to try as i've just about given up!
For reference to this explanation, i'm using a PC running windows 10 and my setup is 2x Denon SC6000s with a Reloop Elite Mixer. deck 1 is on the left, deck 2 is on the right.
When I fire up Virtual DJ it recognises all the devices (shows both SC6000s and the Mixer in the controllers tab) on both the screens on the SC6000s it asks me to select to control either Deck A or B
If I select Deck A on deck 1, that sets to Deck A as expected (all goes blue) but the screen on deck 2 also sets to Deck A. The jog wheel and buttons etc are all correctly set to Deck B though (all goes red).
If I then press the deck selection button on the deck 2 and select Deck B, both SC6000s then set themselves to Deck B, screens, buttons, everything.
Its like the screen on deck 2 is a duplicate of the screen on deck 1, rather than being 2 separate screens.
I'm using the deck selection button on the actual touch screen of the decks as the "deck selection button" flips between A/C or B/D. The mapping section of VDJ doesn't take into consideration the touch screen buttons that I can see so I don't know where else to check.
Decks have been assigned in the Controller config section of VDJ.
I've tried firmware updates, full reinstalls of VDJ, different cables, different ports, different computers, with/without USB hubs but always get the same issue.
Does anyone have any other suggestions about what might be causing this behaviour? as all things I can find on the internet suggest I really shouldn't be having these issues!
geposted Wed 11 Dec 24 @ 6:48 pm
