why is it that occasionally when i’m in the is VDJ browser typing in a song , the music will cut off for a few seconds and the VDJ program will begin opening a second VDJ program in the browser on my 2021 Macbook pro
geposted Fri 20 Dec 24 @ 2:59 pm
Sounds like a memory problem or damaged OS
geposted Fri 20 Dec 24 @ 4:13 pm
a memory problem with my mac?
geposted Fri 20 Dec 24 @ 5:57 pm
any possible suggestions to resolve it? It’s annoying when the music shuts off for 5-10 seconds in the middle of a song. it only does it when i type in a search
geposted Fri 20 Dec 24 @ 5:59 pm
Thanks in advance
geposted Fri 20 Dec 24 @ 6:00 pm
If it is a crash and restart (one process spawn) given you've connected the internet on one of the subsequent startups, the Ayomix devs can probably obtain a crash report on their end - it's better to work with support or ask them directly here as they are fairly active here. You might want to see if there are any crash/diagnostics reports on your system as well.
If it's a new process spawn while an existing one is still there that is weird and it's probably better to go to support with that anyways.
geposted Fri 20 Dec 24 @ 7:44 pm
Thanks so much, i believe you are spot on, it is a crash shutdown and the other one opens on its own. Sorry for my ignorance but how do i find my crash on my 2021 macbook pro?
geposted Fri 20 Dec 24 @ 8:04 pm
Open Spotlight -> Type "Console" and open it -> In the Console, go to Crash Reports
https://support.apple.com/en-ca/guide/console/cnsl1012/mac
No guarantee of a record though.
geposted Fri 20 Dec 24 @ 8:22 pm
Thanks a ton!
geposted Fri 20 Dec 24 @ 10:37 pm
bad drive if a standard drive, a bad stick of ram. Software conflict or bad usb connection to your controller.
geposted Sat 21 Dec 24 @ 12:39 am
Thanks, i used a different controller last night and not 1 issue! Thanks everyone!!!
geposted Sat 21 Dec 24 @ 5:01 pm
last night VDJ shut down twice, second time completely locking up the Mac, again it happened when I was typing in a search. I did use a different usb and controller. I did check my MacBook Pro crash report as was suggested earlier but there was no record. My Mac IT friend suggested I check the VDJ app diagnostics and report the result to Atomix to see if they could figure out the issue. I am using a 2021 16" M1 MacBook Pro and this is the ONLY issue Ive ever had with this unit. Thanks in advance to anyone who can point me in the right direction.
geposted Sat 28 Dec 24 @ 11:29 pm
I still think it's bad memory
geposted Tue 31 Dec 24 @ 3:15 pm
This has happened to me on an older machine 2011 intel, upgraded in January to an M3 MBP and it has happened 4 times since the new install. I have resorted to shutting down the stem separation completely. I will see what happens for Tommy’s gig , hopefully no more crashes.
geposted Wed 19 Mar 25 @ 9:15 pm
