Hi, I need help with a video function. I would like to know if there's a way to make the video image display a text automatically, where the text is read from a tag, for example, from comments.
I'm not sure if I explained myself well, and if anyone has done something similar.
Thanks in advance.
Thanks in advance.
geposted Mon 23 Dec 24 @ 2:57 pm
A video skin (overlay) could do that, same as some display Artist, title etc, could be modified to display other database fields and keep them for a while or the entire Track time.
Edit one of the default video skins, see if you edit/change one, or ask for help here.
Nr.2 https://www.virtualdj.com/manuals/virtualdj/settings/interface.html
geposted Mon 23 Dec 24 @ 3:02 pm
I've made video skins for people, this was the last decent sized job I did.
Client specified pretty much everything you see in this still for his dance school events, then I added some animations to[show off] make it something special
As mentioned above, to edit something existing is pretty easy, a good starting point to learn the basics of skinning [it's mostly like html] and we're all up for people learning how to skin.
But if you want something making send me a pm.
geposted Mon 23 Dec 24 @ 4:11 pm
