What's the default pitch bend number for Virtual dj? I'm trying to get the pitch bend to sound like serato. I have two of the same tracks on each deck and when I move the jogwheel in the song the song sounds better with Serato for some reason?. I had changed that number but I made it worse.
geposted Thu 26 Dec 24 @ 5:11 pm
Could you describe what you mean by "sounds better"?
geposted Thu 26 Dec 24 @ 5:18 pm
Well while I'm moving the song slowly with the jog wheel. It gives off a smoith flanger effect. When I try it with Virtual dj the song is making popping noise and the flanger doesn't sound the same anymore.
geposted Thu 26 Dec 24 @ 6:46 pm
To start, hearing a flanging sound on pitch bend isn't normal to me, the slowdown/speedup should be as smooth a sound as possible. Any weird alteration sort of implies that you are trying to use the jogs too aggressively in JOG mode.
If you are hearing pops/clicks, that could indicate that your latency is too small for the operation you are doing on your computer. Try increasing the latency to a higher power of 2 value and see if that resolves that pop/click issue.
Also, what is your pitchQuality set at? If it's at 1 or 2, try increasing it to 3 (making adjustments to your latency as required) and see if that helps.
geposted Thu 26 Dec 24 @ 7:06 pm
My pitch Quality was at 3 I set to 4 and then I raised the latency to 4098 and set the Jogsensivitybend to . 0.030000. It sounds alot better now. Thanks for the quick response.
geposted Thu 26 Dec 24 @ 7:26 pm
