Hi,
I often use the Color FX "Loop Roll". Today I thought it would be smart if I could additionally add and controle the FX "Filter" on top. So that I could use both effects at once, but control each of them individually.
Is that possible?
Is that possible?
geposted Sat 28 Dec 24 @ 9:44 pm
loop roll as a colorfx already has a filter applied, it's just super low/high freq until you push it to 1/4|1/8th lengths.
Both loop roll and filter are standard fx use them to get the sound you want.
Technically it could be done with the one colorfx dial by using a virtualfx but the tuning required wouldn't be worth if for the results, better to use the 2fx and 2 dials to have full control with the most ease.
geposted Sat 28 Dec 24 @ 11:19 pm
