Hi,
I recently bought an additional controller having many pads, next to my regular controller. As stated correctly in the software manual, the Pro layout shows now 16 pads, in 2 rows (the FX section has been replaced by an additional pad section). That is fine, however, I would like the possibility to select 2 different pad pages - one selected from my first controller, the other from my second controller. Is that possible?
geposted Sun 05 Jan 25 @ 1:24 pm
Yes, just select the pad page you would like to use on your other controller
geposted Sun 05 Jan 25 @ 1:56 pm
I did that, but both change. I would love to have one pad page fixed for using on samples (and controlled by my Akai MPC Mini MK2) an the other pad page for hotcues, loops... the regular stuff.
geposted Sun 05 Jan 25 @ 1:59 pm
Perhaps you mean APC not MPC.
If so, why dont you set your AKAI to the "Drums" mode and trigger Samples from there ?
https://www.virtualdj.com/manuals/hardware/akai/apcminimk2/layers/drum.html
geposted Sun 05 Jan 25 @ 8:43 pm
Thanks. It is indeed the APC.
I use that mode also, but it doesn't allow the new sample features such as Stem replace (it just triggers the samples, that's it). So i prefer to use the other modus.
geposted Mon 06 Jan 25 @ 8:31 am
