I'm using the latest version of VirtualDJ on my DDJ-FLX4 and I'm wondering if there is a way to use the stems separation on performance pads and have a smooth fade out / fade in when i activate it.
I believe Serato has this by default and it's shown in this video at the 0:09 second mark:
https://www.youtube.com/shorts/50Zhh6GDvIs
Is there a way to have it the same / at least similar? Through some scripts and mapping? As of now, when I activate stems separation through performance pads, it does a hard cut. Appreciate any help, thank you.
- I understand that I can achieve this with knobs, but I like using knobs for the traditional EQ mixing.
- I also know that there's an "Instrumental Echo" or "Vocal Echo" button on one of the stems layouts for performance pads that does an Echo Out of the vocals / instrumental, but that doesn't make a fade in when I turn the vocals / instrumental back on. And it also introduces another problem where a backspin doesn't sound natural and I have to manually turn off the vocals and then the "Vocal Echo" effect afterwards to have a good sounding backspin, but that's another problem...
- I also know there's a "Vocal" CFX on VirtualDJ, but I like having this CFX knob reserved for either Reverb, Filter or Echo, I'm looking for this specific solution through performance pads.
geposted Tue 21 Jan 25 @ 2:29 pm
