Does the new Denon Prime 4 Plus work well with VDJ? Any issues?
geposted 2 days ago @ 4:44 pm
It's exactly the same as the old one from a VDJ perspective so yes, it works with no issues.
However it is primarily an Engine DJ standalone controller so a very expensive way of doing things if you're going to use it exclusively with VDJ.
geposted 2 days ago @ 4:47 pm
I am almost satisfied.
geposted 16 hours ago
