I use OBS as a virtual cam for VDJ.
I have a Windows machine with a RTX card running the game ready driver 566.36.
When I upgraded to the latest RTX driver 572.16, I lost the ability to use OBS as a virtual cam. The choice was still available in the cam section of VDJ, but it would only appear as a black screen.
Interestingly enough, Droidcam which uses OBS also, was a selection and still worked.
I switched back to the older RTX driver and OBS virtual cam started working again.
Does this suggest an OBS, RTX, or VDJ problem?
What do you think?
What do you think?
geposted Sat 01 Feb 25 @ 12:37 pm
The RTX driver is borked. It's affecting video output as well.
geposted Sat 01 Feb 25 @ 12:50 pm
