I am trying to map a pad to flash once a request is received and then when I click the pad it will open the ask the DJ sideview tab. Looking at forums I can get the pad to select the sideview tab with (sideview 'askthedj://') and I can get the button to flash using this script (get_askthedj_unread ? blink 400ms : param_equal `get_browsed_folder` "Ask the DJ" ? goto_last_folder : browser_gotofolder "askthedj://"). However when I get a request cliking the pad does nothing and I have the select the tab manually. Once I've selected this and the flashing has stopped the pad will then open the ask the DJ file. Has any one a script that will achieve my outcome or am I asking to much? Thanks in advance.
geposted Wed 05 Mar 25 @ 9:27 pm
( get_askthedj_unread ? blink 400ms : ) & param_equal `get_browsed_folder` "Ask the DJ" ? goto_last_folder : browser_gotofolder "askthedj://"
geposted Wed 05 Mar 25 @ 9:43 pm
@ Locodog,
Exactly the same problem here. With the given script use then nothing blinks but the message has come in. So I use my old script again so that I at least see something coming in.
geposted Tue 06 May 25 @ 9:44 am
@Locodog
The problem seems to be in the first part:
"get_askthedj_unread ? blink 400ms :"
If a message comes in and the blinking starts, nothing happens when you press the button. But if no message has come in, you can switch browsers.
geposted Tue 06 May 25 @ 10:00 am
( get_askthedj_unread ? blink 400ms : ) & & param_equal `get_browsed_folder` "Ask the DJ" ? goto_last_folder : browser_gotofolder "askthedj://"
geposted Tue 06 May 25 @ 3:18 pm
@Locodog
Thanks for your response. "& &" was the solution. Everything works fine again.
geposted Wed 07 May 25 @ 3:28 am
This is what I use, dont remeber who helped me do this but it works great !
get_askthedj_unread ? blink 375ms & up? show_splitpanel 'sideview' on & sideview 'askthedj://' : nothing : sideview 'askthedj://'? on & up? sideview 'askthedj://'? show_splitpanel 'sideview' off & sideview 'Sidelist' : show_splitpanel 'sideview' on & sideview 'askthedj://' : nothing : off & up? sideview 'askthedj://'? show_splitpanel 'sideview' off & sideview 'Sidelist' : show_splitpanel 'sideview' on & sideview 'askthedj://' : nothing
geposted Wed 07 May 25 @ 5:00 pm
@Freppa
Wow.., that's quite a story, but it does work.
geposted Thu 08 May 25 @ 12:20 pm
From ChatGPT:
VDJscript treats & & as two separate logical OR conditions (& being shorthand for OR in some VDJ contexts, like filter folder syntax).
geposted Mon 19 May 25 @ 8:23 am
Chatgpt is worthless when it comes to vdj script. And the reply you posted from it is entirely false.
geposted Mon 19 May 25 @ 8:32 am
That is also the reason I brought this to attention. & & is the solution, nothing wrong with that.
geposted Mon 19 May 25 @ 9:05 am
