Hello!
I made three buttons with stem fx. I used code like this:
padfx "echo out" 70% 1bt "stemfx:MeloRhythm"
What I want it to do now is to turn off the buttons for rhythm, bass and melody if I activate the echo, so I have a visual that these stems are currently not active. Is this possible? Or would the echo not work, if it turns off the lights from the stems.
If it is possible what code do I have to add after the code I posted?
Thanks for your help!
geposted Sat 22 Mar 25 @ 8:26 am
