Im using using pioneer XDJ-RX3. When im using virtual dj but it's playing on my controller under the rekordbo skin , also when I m trying to use the samplers it just playing through my headset not from speaker. Please let me know what's wrong. Tnx
geposted Sat 29 Mar 25 @ 1:51 am
I have the same problem. If I switch "XDJRX3-MixerMode" from MIDI to hardware, it works, but then all gain adjustments disappear.
https://www.virtualdj.com/manuals/hardware/pioneer/xdjrx3/mode/index.html
I haven't found a solution for how to do it in MIDI mode.
I hope someone else has a solution!
geposted Wed 02 Apr 25 @ 6:04 am
Setting SamplerOutput is at 0 ?
If so, it means Sampler is output to "All Decks", but i guess you need to make sure some Channel faders need to be up to reach Master.
geposted Wed 02 Apr 25 @ 11:30 am
Exactly this. I use the RX 2 (my own) and RX3 club units often and without the channel faders up in in hardware mode you will not hear any samples.
To control the volume of your samples while in this mode you can use the aux volume of the unit as the samplers volume level.
geposted Wed 02 Apr 25 @ 2:59 pm
