Hey everyone! I have a Pioneer DDJ800 that doesn't have onboard stems and i'm trying to map my gain knobs on decks 1 and 2 to work as a instrumental and accapella sweep. I dont want to lose my eq function on my controller so I don't want to use stems there. can anyone help with how that can be done?
Thanks
Dave
Thanks
Dave
geposted Thu 03 Apr 25 @ 5:10 pm
map gain dial as stem FullVocal
geposted Thu 03 Apr 25 @ 5:14 pm
Thanks Locodog don't mean to sound dumb but where is that located? or the script for that effect?
geposted Thu 03 Apr 25 @ 5:34 pm
Settings > Controllers, select your device, scroll down the list until you see "gain"
remap the action.
remap the action.
geposted Thu 03 Apr 25 @ 5:50 pm
Thanks LOCODOG
geposted Thu 03 Apr 25 @ 6:15 pm
Worked perfectly! thanks for the help LOCODOG
