Hi
I know this subject has had a bit of coverage but has anyone managed to buy a new laptop that runs flawlessly with audio? I'm a Serato user but also use VDJ and have purchased and returned 4 high spec laptops that just won't run without glitches, drop outs, pops, crackles etc.. I have tried the tweeks that other forums recommend for DPC Latency issues but having to do all this with brand new laptop seems crazy! My 13 year old PC Specialist machine runs flawlessly even using real time stems is smooth. What laptops do people recommend, no the usual "get a Mac" reply as according to these other forums they have also had latency issues. Plus I'm windows I don't like Mac.
Any advice would be amazing
Cheers Ant
Cheers Ant
geposted Mon 07 Apr 25 @ 10:35 am
I would like to know what brand and models you have tried and returned first?
As I understand it is that the graphic card need to be good as a lot of GB ram, and think the newer serie the better it will be for the stems.
I use an old Asus and still works, and I would go for same brand again when its time.
geposted Mon 07 Apr 25 @ 6:02 pm
It seems to be the power saving Intel mid range 13th & 14th gen processors that are the main issue.
geposted Mon 07 Apr 25 @ 6:25 pm
I recently bought 2 Lenovo 9i Pro Yoga 16" touchscreen laptops. i9, RTX4060, 32gB memory, Win 11 Home. I installed 2 4tb NVMe drives in each of them. Takes anywhere between 8-12ish seconds to do a STEMS file in full quality.
I run an Anker USB-C hub that I plug my controller, HDMI, mixer sound card into and also and power an HDMI splitter.
They both run flawlessly.
geposted Mon 07 Apr 25 @ 10:17 pm
Hey DJDONN
Good to hear you have managed to buy a laptop recently that is working without the usual audio glitches that all new laptops seem to have. Can you tell us a bit more about it? What processor is it using? There are many variants here in the UK of that same laptop. Do you have the model number on the back of the laptop and the processor model/generation eg. Intel® Core™ Ultra 9 185H Processor etc...
Also did you have to do any of the tweaks to get it working properly or did it work out of the box?
Any help would be much appreciated
Cheers
Ant
Cheers
Ant
geposted Tue 08 Apr 25 @ 7:22 pm
Hey DJDONN
Can you tell us the specs of your Lenovo? What processor is it running? There are a few different variations of the laptop. Looking to try and get the right one as you say it is running flawlessly.
Cheers buddy 👍
Cheers buddy 👍
geposted Tue 15 Apr 25 @ 7:30 pm
