Hello
How do I delete the default sampler banks (e.g., FX Audio, Loopmasters, etc.)?
Previously, I had to go to C:\Users\xxxx\AppData\Local\VirtualDJ\Sampler and delete the XML file and the corresponding folder.
Since the update, they are no longer found there.
Thank you for your help.
geposted Tue 08 Apr 25 @ 8:39 am
You cannot delete them. They are hardcoded into the software
geposted Tue 08 Apr 25 @ 1:24 pm
