Hello, I purchased the DDJ-FLX10 and was wondering was it compatible with Virtual DJ Pro. I've installed the Firmware and DDJ-FLX10 SETTING UTILITY FOR MAC and its not working? Any suggestions?
geposted Wed 09 Apr 25 @ 12:12 am
https://virtualdj.com/manuals/hardware/pioneer/ddjflx10.html
It should work with the latest stable release.
geposted Wed 09 Apr 25 @ 12:17 am
Thats where I downloaded everything.It keeps not showing audio drivers
geposted Wed 09 Apr 25 @ 12:41 am
It's not detecting the hardware
geposted Wed 09 Apr 25 @ 12:43 am
Given you did install the latest driver and firmware for the device, Macs also now ask if newly connected USB accessories should be allowed to connect.
If you didn't see that, or you clicked no by mistake, you may want to check Security & Privacy to see if it's not blocking the device from being used.
I've used the DDJ-FLX10 on Mac with VirtualDJ before, so it's most likely not a VirtualDJ issue.
geposted Wed 09 Apr 25 @ 1:03 am
Since you are a MAC user, and MAC users have some bad habits:
You need to RESTART/REBOOT your MAC after driver installation.
So, please reboot your MAC and try again. Also make sure that you use the correct USB port
geposted Wed 09 Apr 25 @ 11:41 am
May be a crazy question, but is the Setting Utility for Mac the driver download link for Mac? The description say setting Utility for Mac. on the driver for windows the description say audio driver for windows. .
geposted Wed 09 Apr 25 @ 11:06 pm
Yes they are the same thing.
geposted Thu 10 Apr 25 @ 7:34 am
