whats the script to reset the stems and fx lights back to cue points when you load a new song
geposted Thu 10 Apr 25 @ 4:01 pm
you don't need a script, it's a couple of settings.
type reset in settings see what it comes up with.
geposted Thu 10 Apr 25 @ 4:03 pm
i have them checked for yes but no reaction, it was set before i had to redownload now its not working
geposted Thu 10 Apr 25 @ 4:11 pm
any help real quick
geposted Thu 10 Apr 25 @ 4:56 pm
ok what I'm trying to get and it was incorporated in one of those builds, say like your using stem button and when you load another song you want it to reset including thelight to hot cues. do i need to type in something or what, i have the appropriate boxes checked in the settings but they are doing anything, plus do onit have anything to do with it
geposted Thu 10 Apr 25 @ 5:29 pm
i found it G Thanks
geposted Thu 10 Apr 25 @ 10:12 pm
