I have a few tracks that I want to shorten, I have tried the track cleaner but not had any joy. Is there an easier way to trim tracks, cheers Alf
geposted Sat 12 Apr 25 @ 10:30 pm
Use a DAW instead to do that.
geposted Sat 12 Apr 25 @ 11:33 pm
You could use the POI editor. For instance when bar 5 arrives, add a POI that skips to bar 17 (etc). Might be preferable to using a DAW as it's not permanent.
Also VDJ has "remix points"
It's all in the manual -> https://www.virtualdj.com/manuals/virtualdj/editors/poieditor.html
geposted Sun 13 Apr 25 @ 2:52 pm
