Hi, I am using the default pro skin (which i love and i dont want to change).
I would like for it to display the 4 waveforms at the same time as i've seen on other skins.
Is there an easy way to do this?
geposted Tue 15 Apr 25 @ 11:30 am
Yes, if you set it to 4 decks in the layout dropdown you get the pro skin with 4 waveforms at the top and 4 deck waveforms. Only the scratch waveforms are then limited to 2 waveforms:
geposted Tue 15 Apr 25 @ 1:44 pm
Thank you for your reply!
What you have is exactly what i want!!
However, there must be another obscure setting that hides/displays the waveforms.
When I select the 4 decks option it shows me the 4 decks but it still only shows the 2 waveforms!
You can see on my attached photos, i have 2 decks and 4 decks, and on both it only displays 2 waveforms!
geposted Tue 15 Apr 25 @ 3:36 pm
managed to find it!
when you switch to 4 decks from the dropdown, a new option appears on the waveform dropdown that allows you to display all 4 waveforms (so 2 separate settings).
once again thank you for your reply. the fact that you showed me it was possible made me believe and find the solution! :)
geposted Tue 15 Apr 25 @ 3:48 pm
hope this help.!!!
geposted Tue 15 Apr 25 @ 3:52 pm
geposted Tue 15 Apr 25 @ 3:54 pm
FD-SALSOUL-DJ wrote :
hope this help.!!!
yes! that's the option i couldn't find! thank you!
geposted Tue 15 Apr 25 @ 4:05 pm
