I am coming directly to the source as my frustration level can go no higher. I love VDJ and want to use it for karaoke. How do I use my 300,000 zipped karaoke files with VDJ? I have tried older versions, newer versions and no luck. I have tried to unzip a few songs but that doesn't seem to work either. Can someone please walk me through this. Thanks in advance for your help with this.
geposted Thu 17 Apr 25 @ 9:18 pm
Drag the zip file onto a deck and play. You may need to turn on video if you don't have it automatically coming on.
The zip files are treated like any other media file, assuming they are in the correct format.
https://virtualdj.com/manuals/virtualdj/interface/browser/sideview/karaoke.html
geposted Fri 18 Apr 25 @ 12:47 am
