Looking for a laptop but I don't like Macs. I'm using the latest version of VDJ and I have a license
geposted Sat 19 Apr 25 @ 12:17 am
Recommended System Requirements (imo at least double the RAM):
https://virtualdj.com/wiki/Minimum+system+requirements.html
Optimize running (basically run as little over VirtualDJ as possible, always use the drivers the hardware manufacturer provides, remove bloat, don't run antivirus, etc):
https://virtualdj.com/wiki/PC%20Optimize.html
Notebookcheck list of their DPC tests (take with a grain of salt, do your own testing where possible)
https://www.notebookcheck.net/DPC-Latency-Ranking-Which-laptops-and-Windows-tablets-offer-the-lowest-latency.504376.0.html
XMG's article on why DPC latency is important and whay things vould be contributing to spikes, there tests amd laptop recs)
https://www.xmg.gg/en/news-deep-dive-audio-laptops-xmg-dpc-latencies/
Note, XMG seems to do well in both cases for tests (Notebookcheck and their own), and they did make a DJ specific laptop in the past not sure about availabilities either, especially in the current economic climate.
There are responses to similar posts from Windows users on the forums as well, so maybe do a search and check what they recommend.
Otherwise, maybe use these lists to narrow down options, and be prepared to test and potentially return laptops. Also, having DPC spikes doesn't necessarily mean unbearable operation with VirtualDJ - if you don't get dropouts at properly adjusted latency/buffer size for your soundcard for your performances then that is good enough.
geposted Sat 19 Apr 25 @ 12:41 am
Modern Windows 11 Laptops most recently an Intel i7 12th. - 14 Generation have massive latency problem and are therefore unusable for Audio.
User recommend Mac , AMD Ryzen 7 or ARM CPU
geposted Sat 19 Apr 25 @ 5:23 pm
Some of the higher end i7 and i9 are OK, but the consumer level Intel processors found in most laptops are overly aggressive on power saving hence the problem.
geposted Sat 19 Apr 25 @ 5:27 pm
XMG & SCHENKER DPC Latency Overview!
little to no recommendation for Intel Core 12th Gen till Intel Core 14th Gen
geposted Sat 19 Apr 25 @ 5:42 pm
I think the first post I put pretty much covers the DPC problem, why it exists, and some checks from XMG and Notebookcheck. That doesn't mean these newer Windows laptops cannot be used - you would have to dive deeper into the hardware combinations and still have to check yourself, as your use case and experience is the final say.
OP specifically said they didn't want to go the Mac/MacBook route (iMac/MacBooks aren't necessarily the only answer for realtime audio, but is often a good one based on the average specs/setup of a iMac/MacBook).
geposted Sat 19 Apr 25 @ 6:04 pm
in the Notebookcheck List most of them are from 2021-2023 with low DPC
geposted Sun 20 Apr 25 @ 9:10 am
Unfortunately, these are all sold out !!
geposted Sun 20 Apr 25 @ 10:36 am
I have one of these as my home machine for video editing and despite being a 13th Gen i9 it runs really well after tweaking the CPU power settings. Latency is super low and no cracks or pops when playing out with either Denon or Pioneer ASIO drivers.
https://www.asus.com/uk/laptops/for-creators/zenbook/zenbook-pro-16x-oled-ux7602/
It is a pretty high end laptop however and the 280w charging brick is massive.
geposted Sun 20 Apr 25 @ 10:43 am
kradcliffe wrote :
...13th Gen i9 it runs really well after tweaking the CPU power settings. Latency is super low ....
What has you tweaking there ?
Unfortunately, Asus does not have good support when it comes to drivers, software and bios Updates.
geposted Sun 20 Apr 25 @ 1:35 pm
