Ever since VDJ2025 was launched my buttons on the Prime 4 lost functionality
Can't use the page or buttons assigned to the page. Tried to follow guidance but seems out of date how to really assign that functionality again.
Hot cues doesn't work. Neither samples. Every thing has to be clicked via my mouse.
Really need to sort this out and hoping for help from the community
Everything has the latest versions
geposted Sat 26 Apr 25 @ 10:13 am
Do they work with the default Mapping ?
If so, then perhaps you have mapped those incorrectly. Perhaps give more details on what doesnt work, specific pages, some of your custom pads pages ?
geposted Sat 26 Apr 25 @ 5:20 pm
Page pads and the 8 pads are on default mapping and have always been. Even if I try to reset the controller mapping same problem occurs.
They just died.
Is there a way to manually reset the controller from VDJ and start over?
They just died.
geposted Sat 26 Apr 25 @ 5:38 pm
Found the solution
skinPanels, by deleting and re-config the buttons it seems to work again. Had a mysterious line of DNPrime there
geposted Sat 26 Apr 25 @ 6:16 pm
