Hi
If I use custom buttons to adjust the master decks video_fx_buttons or video_fx_sliders they work fine but if the video_fx itself opens up a pop-up window (such as the 'shader' fx) rather than a fly-out from the right (such as 'text') then any adjustments made using the custom buttons are not reflected in the pop up window, either before, after or during the adjustment.
If however I make adjustments in the pop up windows, they are reflected on the custom buttons/sliders.
This has only started recently and altho not a problem for the most part, if slider vfx_slider 1 is moved whilst the 'shader' is active, this will change the active shader but in the pop up it is still showing the last shader selected so it can't be relied on.
Also what order does the 1st slider use when changing the current shader, it doesn't appear to be alphabetical nor does it scroll through the shaders in the currently selected folder, it just seems random (although I am sure there is an order I just can't see it).
Thanks
Thanks
geposted Mon 28 Apr 25 @ 8:46 pm
