CAN NOT LOG IN FROM VIRTUAL DJ PROGRAM
geposted Fri 02 May 25 @ 4:18 am
Support Staff wrote :
something is blocking VirtualDJ from connecting likely.
If you can not connect (and its not something else, like wrong password).
If you already tried the tool [ For PC: For Mac: ], then check your firewall etc..
If unsuccessful you can contact Support Team here, so they can help you with remote access
https://virtualdj.com/help/
geposted Fri 02 May 25 @ 7:22 am
You need VPN! I'm from CHINA.So..I can't authenticate the link in E-MALL through the Chinese network, I can only use VPN to verify the link in my email.
geposted Sun 04 May 25 @ 12:40 am
