Everything has been working perfect until today. Any song I load into the Wright channel plays the music fine but the vocals are barely audible. Left side channel plays everything perfectly
geposted Sat 03 May 25 @ 9:44 pm
I suspect you mean deck rather than channel. Maybe you've got stem EQ enabled and the vocal knob is turned down. Maybe you have 'vocal' selected for ColorFX and the ColorFX knob is not centred.
geposted Sat 03 May 25 @ 9:58 pm
Sorry guys I figured it out. The mid-level EQ was just a teeny bit lower than normal. All I had to do is bump it up by a couple matches and everything was fine.
geposted Sat 03 May 25 @ 10:00 pm
