Have had issues with 2 Brand New Units in the last 2 weeks. Vinyl Mode works for 30 minutes on the Jog Wheels, then they will not work for the rest of the evening. They literally don't do anything when using them. If I power the laptop down and restart they work great for another 30 minutes and same exact thing happens. I am using a New MacBook PRO. I have used the DDJ-1000 for years and never had any issues. I have installed the latest version of Virtual DJ and all updates. Need help ASAP. Thank you!
geposted Sun 04 May 25 @ 6:06 am
Why are you creating another thread on this? You already have one with replies so please do not cross post.
The team will have seen it and will respond accordingly.
You also never mentioned previously you are using a Macbook which may help narrow down the problem.
https://www.virtualdj.com/forums/263746/VirtualDJ_Technical_Support/DDJ-FLX10_Jog_Wheel_Responding_Intermittenly.html
geposted Sun 04 May 25 @ 6:42 am
