I have the rane four, lately I've notice that the instrumental and/or the acapella don't reset like it use to before i updated the firmware to 1.08. I"m using the shift instead of the primary inside the fx section is there a fix, also build 8350.
geposted Mon 05 May 25 @ 11:22 pm
Perhaps u need to enable the resetFXOnLoad setting so that Effects (including Stems FX used in those buttons) to reset when a new Track is loaded
geposted Tue 06 May 25 @ 12:23 pm
