When mapping the Xone K2s in 2 deck 2 device mode, is it possible to have one mapping for two controllers that automatically assign buttons in row 1 and 2 to one deck and row 3 and 4 to the other deck?
The current behavior is that everything in column 1 and 2 get assigned to one and column 3 and 4 to the other. I could override this using the deck 1/deck 2/deck 3/deck 4 subject in front of verbs, but this would mean me having to create a separate mapping file for each of my 2 K2s and whenever I make a change to the first file, I would have to update the second file by hand as well, which is messy.
I've tried the deck left and deck right subject in front of verbs while setting the second K2s decks to 3,4,5,6 but that doesn't work deck left/right just seem to correspond to deck 1 and 2
Is what I am trying to do possible at all?
geposted Fri 09 May 25 @ 7:11 pm
