I've got teo laptops. One of them works without issues and the stems are doing its job. The other one also works properly with the exception of the stems. When i click on a stem on the pad nothing happens. Also tried the seperate FX, same thing. Its a Dell, i5-5300u, 8GB ram, 2GB graphics. I dont think its a performative thing but still. If you've got experience with the same problem or any suggestions I will be thankful!
geposted Sun 11 May 25 @ 4:59 pm
Can you confirm whether you are trying this with or without a controller connected?
I have had an issue in the past where the pads page mapping was wrong and the pads didnt respond, but would work fine if i clicked on the pad in VDJ itself. Once i figured that part out, i was able to clear the mapping and copy it from the working laptop to the non working laptop and pad operation was restored once more.
geposted Mon 12 May 25 @ 3:03 pm
What model/type is the graphics card of this computer ?
What do you have in VirtualDJ Setting StemsRealtimeSeparation ?
Most likely this computer wont be able to do decent/fast real-time Stems separation, so best would be to pre-compute some of your Tracks, unless you can accept the Reduced quality
geposted Mon 12 May 25 @ 3:30 pm
