According to the VDJPedia, cover should have a syntax like this.
However,
does not make the cover art circular, nor does it set the visbility to 30%.
What am I doing wrong?
I have also tried other things for visibility. These all don't work - it's always visible 100%
OFF
FALSE
0
0.5
50%
NO
<cover source="" shape="" rotate="" linkdrop="" visibility="" os="" panel="" deck="">
However,
<cover source="automix" shape="circle" rotate="" linkdrop="" visibility="30%" os="" panel="" deck="">
OFF
FALSE
0
0.5
50%
NO
geposted Tue 20 May 25 @ 5:40 am
If you don't use a parameter, remove it.
Otherwise it will interfere with the element, producing unwanted effects.
<cover source="automix" shape="circle" visibility="30%" x="+0" y="+0" width="50" height="50" /> should work fine.
Also <cover source="automix" shape="circle" visibility="constant 0.3" x="+0" y="+0" width="50" height="50" /> should work as well (since visibility accepts scripts)
PS: Question like this is better to be asked on the SKIN forum next time. Thank you!
geposted Tue 20 May 25 @ 12:06 pm
<cover source="automix" shape="circle" visibililty="30%" rotate="no" x="1920/2-350" y="1000/2-350" width="700" height="700" />
Above is the exact code I'm using. I can once again cofnirm that I have no circle, and no transparency
EDIT: I mistyped visibility ... .... OMG - But shape still does not work without rotate.
geposted Tue 20 May 25 @ 8:30 pm
