How do I stop auto load into nonplaying deck? If I want to select a song to put in waitlist it autoloads into whichever deck is not currently playing, even If I have my next song in the deck already qued to play. I've looked through the "Edit Mapping"
section but not sure where to look.
geposted Sat 24 May 25 @ 6:29 pm
If by "waitlist" you mean "Automix" it doesn't load anything into any deck by default, unless you started automix.
AFAIK there isn't any other list that automatically loads to a deck by default, so if you mean the automix list, maybe start by disabling automix?
Read more about it here:
https://virtualdj.com/manuals/virtualdj/interface/browser/sideview/automix.html
geposted Sat 24 May 25 @ 6:52 pm
If you're double clicking it will load into the first deck it can.
I made a thing for a Boston FM radio station that just couldn't give up the behaviour that double click means add to the stack, it was complicated and I was paid thousands of US$ but that included about 6 plugins, a dos database conversion, a skin. Proper money for proper work.
I can't remember exactly how I did it..., I had to let it load on deck because that's what double clicking does and then I sent it off deck into a list, I can't remember how I detected it was a double click load.
I could go back and look at the code but it's technician's rates. If you're a radio station a few hundred is no big deal, but if you're a 1 man operation, my advice is just don't double click, make a button to send to list.
geposted Sat 24 May 25 @ 7:13 pm
