Hi all. just connected mic to rane four but not getting any sound out.. i guess i'm doing something wrong somewhere.. maybe settings on vdj an/or rane four. mic audio set to rane four asio in vdj and rane four mic setting set to computer. tried other mics an leads, still same. mic on and gain up.
geposted Mon 26 May 25 @ 1:56 pm
Audio config looks like this?
Are you wiring into mic port 1 or 2?
geposted Mon 26 May 25 @ 1:58 pm
tried using both.. same on both.
geposted Mon 26 May 25 @ 2:13 pm
any other suggestions.. any help appreciated
geposted Mon 26 May 25 @ 2:32 pm
test the mic is good, try it on your sound in jack on your machine.
geposted Mon 26 May 25 @ 2:39 pm
tried 3 different dynamic type mics.. still same problem, they work ok on old pioneer mixer. help to resolve needed please
geposted Mon 26 May 25 @ 4:11 pm
state of setting microphoneToMaster
geposted Mon 26 May 25 @ 4:37 pm
mic set tomaster in vdj options
geposted Mon 26 May 25 @ 4:49 pm
mic set to on in the vdj mixer master section?
I'll need to see a screen shot of your audio config
geposted Mon 26 May 25 @ 5:06 pm
mic is on in vdj , however in rane mic menu there's no master out option, only booth, headphone or computer.. is this correct do you know ?
geposted Tue 27 May 25 @ 9:29 am
also audio config is same as screen shot sent
geposted Tue 27 May 25 @ 9:39 am
I'd still like to see it, have you tested the unit with serato?
geposted Tue 27 May 25 @ 11:59 am
What if you put the Rane Four Mic setting "To computer" to Off ?
Normally, the Mic signal should be routed directly to the Master Outs of the Rane Four, assuming the MIC ON of the device is enabled and its Level is at appropriate level.
PS. You have speakers connected to the Master Outputs of the Rane, right ?
geposted Tue 27 May 25 @ 12:28 pm
have set booth, headphone, and computer to off. also tried as stand alone..as should work ok on it's own so goggle say's, no laptop connected, still same issue, an yes speakers connected. everything else seems ok. maybe a rane issue an not vdj.. i'm at a loss
geposted Tue 27 May 25 @ 2:30 pm
you've proven the mic, and the controller failed the stand alone test. This is 100% an issue to take up with Rane.
geposted Tue 27 May 25 @ 2:37 pm
thank you for all the help, apologies taking up your time
geposted Tue 27 May 25 @ 2:42 pm
