Hello, it's been seven years since I started using this amazing program.
1) the only one that has good bpm analysis (never fails) (just sometime that calculate half for songs over 140bpm)
2) No matter what tool I connect, it will be recognised and ready to use.
3) Additionally, I can use more than one controller at the same time and have multiple exits.
The only sad part is the export features.
To be ready to go to venues without the computer, you need to export the playlist to a USB stick.
I see my colleagues at the venues with usb3 or external SSD done with the "rb"... yes, the worse program on the planet (my opinion) 🥲🥲🥲🥲
If I connect a USB3 stick or an SSD to Virtual DJ, it is not recognised at all as exporting. 🥹😢🥲😭😭
I really beg you to develop something.
best regards.
best regards.
geposted Thu 29 May 25 @ 7:58 am
