I’m wanting to be able to load 4 different tracks quickly to different decks. Is this possible?
    geposted Thu 29 May 25 @ 8:38 am
          One way - as a preparation - can be done using the save_deck_set and load_deck_set actions.
If you want to load specific Tracks with one button, you can do with the load action providing the exact paths of your Tracks ...
deck 1 load "PathToTrack1" & deck 2 load "PathToTrack2" & deck 3 load "PathToTrack3" & deck 4 load "PathToTrack4"
If the above not good enough for your workflow, perhaps give more details.
geposted Thu 29 May 25 @ 12:04 pm
Most controllers have a load Deck A and Load Deck b button, assign a load deck c and deck d and with just a click of a buon you will load decis instantly
geposted Thu 29 May 25 @ 12:22 pm
          Thanks for your reply I’ll give it try.
    geposted Fri 30 May 25 @ 8:18 am
          What I’m trying to do is replicate what I used to do on my old Denon DNS 5000s. I’d have 4 different tracks set up on the 4 hot cues on each deck so, I’d have 8 different songs I could quickly mix between or cut in. Will the method above be able to do something similar? Thanks for any help in advance.
    geposted Fri 30 May 25 @ 8:30 am
          look at scratch banks, that seems more in line with what you want to do.
    geposted Fri 30 May 25 @ 9:15 am
          That’s exactly what I’m looking for. Thanks a lot for your help
    geposted Fri 30 May 25 @ 11:42 am
