I bought a Bluetooth microphone and was messing with the mix fx plugin but couldn't get it to work. I have the mic plugged in my dj controller but nothing. Can someone help me out?
geposted Thu 05 Jun 25 @ 11:13 am
How do you plug in a Bluetooth microphone?
Also, depending on the controller you use, the mic input might be routed to the output directly and does not go through vdj.
You can check the VirtualDJ manual for your controller to get more information
geposted Thu 05 Jun 25 @ 11:51 am
