Lowering the key of songs mostly makes the drums sound musty and dull.
Is there an easy way to change the key of "MeloVocal" without touching the drums?
A "stems_split" Drums = deck 3 and "MeloVocal" = deck 1 could be one option...
Better was somthg like key_move "MeloVocal" -1
Any Ideas?
Any Ideas?
geposted Thu 05 Jun 25 @ 8:38 pm
Call effect_stems melovocal, then call pitch effect
EDIT as of BUILD 8630
effect_active melovocal pitch & effect_show_gui melovocal pitch
geposted Thu 05 Jun 25 @ 10:17 pm
Thank you for this idea. However, the quality is much better with the native keychange function.
So ‘stems_split rhythm’ and with ‘unlink’ you can change the key as desired. The drums remain at their original pitch.
BUT with ‘unlink’ you are no longer flexible. You can't jump to a cue. Also If you change the tempo, the split stems diverge.
So something for the Wishes forum:
having a scriptsyntax like
That would be very helpful
splits_stem no key
geposted Sun 08 Jun 25 @ 11:21 pm
