Hi,
I would like to display on a third party app/system the current track playing.
My use case is being able to display it on a Awtrix display - (It's like a LaMetric device but open source).
Is there a way to acheive that ?
Thanks a lot team !
Thanks a lot team !
geposted Mon 09 Jun 25 @ 9:34 am
tracklist.txt from ...VDJ/history folder
you could pull details on demand with networkcontrol plugin.
For windows I've made plugins that write to a text file the moment the master designation swaps sides.
geposted Mon 09 Jun 25 @ 10:11 am
Thanks, what is your plugin ?
And i don't find networkcontrol plugin ?
Could you help me ?
Thanks
Could you help me ?
Thanks
geposted Mon 09 Jun 25 @ 10:30 am
pfff we simple search i find the networkplugin sorry.
geposted Mon 09 Jun 25 @ 10:33 am
Now I need to find how to use the API.
I search this time ;) but I don"t find any documentation.
geposted Mon 09 Jun 25 @ 10:43 am
https://virtualdj.com/wiki/NetworkControlPlugin.html
After that it's just script
geposted Mon 09 Jun 25 @ 10:46 am
Ok got it ! You rock thanks !
geposted Mon 09 Jun 25 @ 10:50 am
I made progress ; )
I'm able to get the current song from deck 1 & 2 and if the song is audible.
And after i'm able to send the rigth message based on those values on my display.
But for that I need to call 6 times the query?script API
Perhaps there is a better way to do it no ?
Thanks
// DECK 1
1) query?script=deck 1 get_loaded_song 'title'
2) query?script=deck 1 get_loaded_song 'artist'
3) query?script=deck 1 is_audible
// DECK 2
4) query?script=deck 2 get_loaded_song 'title'
5) query?script=deck 2 get_loaded_song 'artist'
6) query?script=deck 2 is_audible
Thanks
geposted Mon 09 Jun 25 @ 1:01 pm
query?script=deck master get_artist_title
geposted Mon 09 Jun 25 @ 2:28 pm
ok but it does not take into account if the track is playing.
But at least it saves some api call
geposted Mon 09 Jun 25 @ 3:15 pm
Ok with the combination of
I do what i want.
So 2 calls instead of 6. not bad ! ;)
Thanks
deck master is_audible
I do what i want.
Thanks
geposted Mon 09 Jun 25 @ 4:59 pm
query?script=deck master is_audible ? deck master get_artist_title
geposted Mon 09 Jun 25 @ 5:40 pm
Thanks again ;)
So with that if no sound on master i get error:1 else i get the Artist - Title of the deck that is playing.
If 2 decks is playing i got the one with the "biggest crossfader".
Now only one request !
Super cool !
Thanks Big Virtual Dj Master !
Super cool !
geposted Mon 09 Jun 25 @ 6:19 pm
query?script=deck master is_audible ? deck master get_artist_title : get_text ''
geposted Mon 09 Jun 25 @ 6:21 pm
I start to understand the syntax
And how i can mix multiple information like title artist and the remix with the key "get_remix_after_title" ?
After i think/hope i can be autonomous ;)
I try
I try
query?script=deck master is_audible ? deck master get_artist_title & deck master get_remix_after_title: get_text ''but does not work
geposted Mon 09 Jun 25 @ 8:14 pm
query?script=deck master is_audible ? get_text '`deck master get_artist_title` `deck master get_remix_after_title`' : get_text ''
composite get_* queries need to be consolidated with
get_text '`script grab a thing` outside of the backticks can be raw text `grab another script thing` more raw text if you want'
geposted Mon 09 Jun 25 @ 9:43 pm
Thanks a lot ! it works perfectly !
Here the result :
Here the result :
geposted Tue 10 Jun 25 @ 4:25 pm
