I updated Virtual DJ.
Since then, the "Sound Color FX" and "Beat FX" sections of the Flx10 no longer work.
And I can no longer display the remaining time in the jog wheels...
Help...
Help...
geposted Sat 21 Jun 25 @ 9:14 pm
What build?
I'm currently on b8615 and it's working fine here.
geposted Sat 21 Jun 25 @ 10:31 pm
I'm on the 8645.
I've just seen it's a early access...
I will reverse to the previous version.
I need to find the option to desactivate the early access version to be downloaded
geposted Sun 22 Jun 25 @ 3:15 am
Just tried with EA Build 8645 and everything works fine on the FLX-10, including Color FXs, Beat FXs (on Deck and Master) and Stems FX too.
Is it just the Time not displayed, or the entire Jog Screen not working ?
Can you try to re-install the Mac Utility ? https://support.pioneerdj.com/hc/en-us/articles/16716526415641-DDJ-FLX10-Setting-Utility-for-Mac (and make sure you allow the App to have the requested access)
geposted Sun 22 Jun 25 @ 5:58 am
Very strange.
Yesterday I restarted twice the MacBook and the Flx10 with no success.
Today at home, everything is working fine again
geposted Sun 22 Jun 25 @ 11:03 am
I have the same issue with the FX on Mac, since yesterday.
geposted Sun 22 Jun 25 @ 8:40 pm
@BEROJ23
Topic is specific to an issue of a DDJ-FLX10 user, which seems to be resolved.
Could you explain your case ?
geposted Mon 23 Jun 25 @ 10:07 am
Today, the effects work as they should. But now I no longer have a needle indicator on the right jog display. It's there on the left one.
Build 8645
Build 8645
djdad wrote :
@BEROJ23
geposted Mon 23 Jun 25 @ 8:31 pm
Did you try the button on the controller to bring it back?
geposted Mon 23 Jun 25 @ 8:39 pm
Ok, I get it! (Double klick on shift button)
Now everything work fine, thank you for the help!
geposted Mon 23 Jun 25 @ 8:50 pm
