Are there any good tutorials on how to use Automix live.
I am struggling to use it as it seems to mix in different tracks other than the one I select to Mix Now, No Sync Mix or Mix selected
geposted Tue 24 Jun 25 @ 10:41 am
have you tried the manual
https://www.virtualdj.com/manuals/virtualdj/interface/browser/sideview/automix.html
there is also a video bottom of page
plus the tutorial videos inside vdj options
and there is this https://www.virtualdj.com/help/videotutorials.html?view=quicktips&episode=automix
geposted Tue 24 Jun 25 @ 12:48 pm
Not really helped on " how to use and set up automix live"
geposted Mon 14 Jul 25 @ 10:53 am
https://www.youtube.com/results?search_query=how+to+use+virtual+dj+automix+live
i mean ask more specific questions if you want more specific answers
geposted Mon 14 Jul 25 @ 11:34 am
IMO saying "automix live" is a contradiction in terms. Automix is something to use when you don't want to DJ yourself. You set it going and leave it to mix automatically (hence the name). If you're DJing live then you wouldn't use something that takes over from doing it manually.
geposted Mon 14 Jul 25 @ 12:57 pm
