Hi, when exporting to CDJ (on a USB key) a first time everything is exported correctly (tags, beatgrids, waveforms, hotcues.etc.). However if I modify the tags or hotcues of a song at a later time on the original VirtualDJ database (the one on my laptop) and export it again on the same USB key, it is not updated on the key (hotcues and tags are not updated). It is the same wether I export by dragging the file on the CDJ Export special folder or export it via a playlist. The message "exporting cues..." appears on the browser bar but in the end the song on the key stays in the same state it was exported the first time.
The key works fine on Pioneer gear or in Rekordbox, it's just that songs are never re-exported after the first time. To update them via VirtualDJ, I have to go on the CDJ Export special folder and edit the songs in that folder. Maybe it is working as intended but it is not very convenient (I mean it is still possible to edit the songs on the key in VirtualDJ, but you have to do it directly on the key, you can't re-export to update previously exported songs).
I'm using export in CDJ2000 compatibility mode and both "auto sync cue points" options checked (but I get the same behaviour if uncheck or check only one way).
geposted Wed 25 Jun 25 @ 7:51 am
