Hey there, i want to use both fx sides of the controller denon prime 4 with the buttons over the gain.
FX 1 & FX2 so i can use on each deck 6 FX at the same time or switch between the fx sections.
Anybody know how can i map it?
geposted Wed 25 Jun 25 @ 4:19 pm
Not easy at all. Will require mapping of many buttons , leds and OLED Display keys.
You can query device_side 'left' ? ActionForLeftSide : ActionForRightSide and then the effect_arm_ actions .
But before that, why do you need 6 FXs at the same time ? I mean even 2 FXs at the same time enabled may not sound well and if you want quick access to some of your favorites , why dont you save/load Effect Banks ?
geposted Wed 25 Jun 25 @ 5:08 pm
I dont want to use all fx at the same time,
but i can hard load 6 fx and start they quickly.
and i have all fx usefull on both or all 4 decks.
So i can route fx 1 & fx 2 to deck 1 & 2
But also i can use only fx 1 on deck 2 and fx 2 on deck 1.
geposted Thu 26 Jun 25 @ 5:49 am
Since you dont usually apply more than 1 Fx on a Deck, it is still wiser to use effect Bank Save/Load.
These actions are available in default Mapping .. Nr.42 https://www.virtualdj.com/manuals/hardware/denon/prime4/layout/effects.html
Here is the workflow...
- Create FX Bank 1 e.g. by having Echo, Cut and Flanger to Slots 1 to 3 on Deck 1. Use SHIFT+FX1 Assign button (Nr.42) to save the selected Fxs (Slots 1 to 3) to BANK 1
- Create FX Bank 2 e.g. by having BeatGrid, Distortion, Reverb to Slots 1 to 3 on Deck 1. Use SHIFT+FX2 Assign button (Nr.42) to save the selected Fxs (Slots 1 to 3) to BANK 2
^ these are the preparation steps.
- Then use the FX1/FX2 buttons to load the desired FX Bank to any of the Decks.
It's just one button away (to select a FX Bank.
Again, what u ask is possible, but it's just long and complex script to achieve this.
geposted Thu 26 Jun 25 @ 8:00 am
I have a skin that does 'fx units' work flow but it needs a lot of hardware remapping as well as the skin.
geposted Thu 26 Jun 25 @ 8:08 am
I give it a try, but it sound not like this function i want to use.
With my idea i have 6 FX ready to use with each site multi Fx mod.
Now i can use one ore more off the fx on all decks.
geposted Thu 26 Jun 25 @ 6:35 pm
you mean something like this
your buttons under the hw fx dials, arm the fx, then the fx1 fx2 buttons trigger the armed fx's.
geposted Thu 26 Jun 25 @ 7:05 pm
Loco it looks like what i want.
Your are amazing.
So the user got a better workflow.
geposted Thu 26 Jun 25 @ 7:15 pm
